Taking of Decal stickers
Old Sep 1, 2002 | 02:10 PM
ZeRo MaX's Avatar
Taking off Decal stickers
Is there anything I can get that can take off decal stickers.. i'm sick of this stupid sticker i have on my car.. i want to take it off... i heard there was a spray that takes off stickers that car seller uses to take off decals... i want to take off the stickers without causing any damage to the paint... anyone know? thanx again!
Old Sep 2, 2002 | 06:10 PM
ZeRo MaX's Avatar
anyone?
Old Sep 2, 2002 | 06:19 PM
MAX's Avatar
MAX
Take it to the dealer and get them to take it off. They probrbly won't charge you, it will take some lot attendant 5 mins.
Old Sep 2, 2002 | 06:28 PM
metallic97gxe's Avatar
Master Will
you need to heat it up w/a blowdryer or a heat gun then it will peel off very easily...then clean the area w/rubbing alcohol to get the area free of the adhesive...
Old Sep 3, 2002 | 07:08 PM
ZeRo MaX's Avatar
rubbing alcohol won't do anything to the paint right?!?
if dealer doesn't do it for free.. then i'm gonna do that way.. blowdry it.. then peel it.. then rub it with alcohol or something else...
Old Sep 3, 2002 | 07:23 PM
Master Will
alcohol will not hurt the paint just don't let it sit to long...use your fingernail to get most of the adhesive off that is left over from the decal...then alcohol...
Old Sep 3, 2002 | 07:36 PM
slimer's Avatar
A couple of Blaxxx's? Lawls.
i picked mine off in 90 degree heat and then used a little bug and tar remover to get the adhesive off
Old Sep 4, 2002 | 10:47 AM
ZeRo MaX's Avatar
i'm gonna try to get it off with the blowdryer method.. if that doesn't work.. or if i want to.. i'll go down to the nissan dealer and let them take it off for me.. i'm gonna get an oil change down there at the dealer too.. how much is it there anyways?? I should get my rims in a week or so... and i wanted to paint my calipers too... so will nissan put my rims on for me with tires i bought.. change my oil.. and take of the decal... if they do.. does anyone know the price of each.. thnax!
Old Sep 4, 2002 | 12:06 PM
redmaxpa007's Avatar
i SeE what you did therE
you haven't asked me.. you were over my house the other day installing the intake.. we could have done it then
Old Sep 4, 2002 | 01:07 PM
ladeesman's Avatar
Dude change your own oil......you don't need to spend that cash...
Old Sep 4, 2002 | 04:24 PM
ILoveMyMax's Avatar
def hot weather and a razorblade
Old Sep 4, 2002 | 08:17 PM
HondaKiller718's Avatar
ditto
Old Sep 5, 2002 | 07:49 AM
StygianMax's Avatar
"Goo-Gone" works wonders for removing adhesive. I've used it on my Max & it didn't do anything to my paint either.
Old Sep 5, 2002 | 09:51 AM
BajaPanty_96SE's Avatar
Re: Taking off Decal stickers
Go to Autozone....I bought some stuff about 2 months ago that is perfect for removing stickers from your car. Just ask one of the guys that works there they should be able to help you find it.
Old Sep 5, 2002 | 03:22 PM
syc's Avatar
syc
and make sure to wax the area to protect your paing ater taking it off. WD-40 is just as good for sticker.
Old Sep 5, 2002 | 05:50 PM
iansw's Avatar
Or go to an autobody store and buy a "pinstripe removal tool"
I got my entire pinstripe removed in 5 minutes with it.
Worked perfectly. No heat gun needed.
IanS
Old Sep 5, 2002 | 07:14 PM
Nore474's Avatar
all these methods can shave off the maxima and nissan emblems right
Old Sep 5, 2002 | 08:31 PM
djmayhem's Avatar
try this
find a can of this stuff called MALCO adhesive remover or something along that line. the malco stuff works great, and i found out about it from a car lot porter(car detailer). peace
Old Sep 5, 2002 | 09:20 PM
DTR Maxima's Avatar
no one has brought this up yet, so be careful when using the blow dryer on your car, if you hold it to close for to long of a period of time you can warp the paint. just keep a couple inches away and dont hold it on one specific spot, run it up and down the sticker.
Old Sep 7, 2002 | 07:33 AM
ZeRo MaX's Avatar
Thanx man... i was gonna try this method... then peel it off with my fingers.. then use somehting to rub the are to get the sticky stuff off... but readin' through this post.. it seems there are many ways.. but none really specific... so i just have to choose one and hope it will not warp my paint or rub my paint...
tarun900
19
Dec 20, 2021 06:57 PM
Apr 16, 2020 05:15 AM
TKHanson
Nov 24, 2018 01:39 AM
mpbclutch33
Dec 26, 2015 11:11 AM
