Upgrading Headlight Hareness... Work?
Old Sep 1, 2002 | 02:26 PM
Sexima's Avatar
Ok... My Nokya headlights are at it again....
2 of them... around 58 bucks... MELTED ON MY HARENESS so I can't take them out... sad huh?
So I finally decided to upgrade the hareness..
will it work? Anyone have any problems using the 80/100 watt bulbs?
I'm thinking of getting
JC Whitney Xenon 80W/100W headlight bulbs
The one 1MAX2NV uses. They match well with the brighter clearence lights.
So anyone have problems with the upgrade?
Old Sep 1, 2002 | 03:00 PM
njmaxseltd's Avatar
I was just on the JC Whitney site looking at bulbs. I used to run their Diamon Blue 80/100 bulbs. Great light from them and I never had a problem with my harness. I have since switched to HID's.
I notice they have a bulb now thats 100/55 Watts. That sounds perfect, just 10 more Watts on the low beam wount burn anything. They have that bulb with Zenon gas which is supposed to make them burn cooler. Why don't you give one of them a try? Every bulb I've ever used from JC Whitney performed quite well.
Old Sep 1, 2002 | 04:22 PM
Sexima's Avatar
you have them upgraded?
Old Sep 1, 2002 | 04:25 PM
iregula's Avatar
holy moly....58??? i spent 18 on these at southwestautoworks.com and i didnt even like them...no light output at all!
Old Sep 1, 2002 | 05:26 PM
njmaxseltd's Avatar
No, all stock wiring with an HID retro kit.
Old Sep 1, 2002 | 07:23 PM
Ravq's Avatar
Re: Upgrading Headlight Hareness... Work?
I'm running 100/80w with a harness and have no problems. Just be sure you ground it well.
Old Sep 1, 2002 | 07:30 PM
Sexima's Avatar
Re: Re: Upgrading Headlight Hareness... Work?
what you mean ground it well
Old Sep 1, 2002 | 08:17 PM
taeMAX97's Avatar
damn i hate you guys... i just posted similar topic about 2 days ago and you guys didn't even reply to my post... (j/k)
well i had the same problem. same bulbs and i had bout 2 sets already. and last one i had it with harness upgrade. and it worked well for a lil bit but now side just burnt out. so i don't know what to do now.
Tae
p.s. is it better to ground it to metal screws than (-)negative side of battery?
Old Sep 1, 2002 | 08:45 PM
1MAX2NV's Avatar
Re: Re: Re: Upgrading Headlight Hareness... Work?
To get good ground use existing OEM ground bolt.
jerrod99_se-l
Aug 27, 2015 08:27 PM
mpbclutch33
Aug 25, 2015 06:23 AM
KristyKarina
Aug 23, 2015 09:53 AM
Samedi
Aug 12, 2015 01:54 AM
kenc15
Aug 5, 2015 08:29 AM
