need help with set up on sprint/agx help!!
Old Sep 2, 2002 | 11:29 AM
RI-Max's Avatar
ok guys i done seachers etc. and im still lost. ok i got the sprint springs already on my car with the factory shocks and i like the drop. but i need new struts casue i blew the rear ones. now i wanna get the kyb agx from nick bauer for 350 and i need new dust boots casue mine a gone cut up etc. im kinda lost where to put the wire warp on the spring i took off the wire warp off the stock ones and put them on the sprints but i heard peeps saying to do the top. can some one just let me know where to put the wire warp casue i was thinking about useing a shop air hose and cut it up?? and what esle do i need for the drop???
Old Sep 2, 2002 | 01:03 PM
Lime's Avatar
1) Coil wrap can be purchased at Lowes, Home Depot, or Radio Shack. Here is a link...
http://www.radioshack.com/product.as...Fid=910%2D5176
If that doesn't work, try searching for wire wrap on their site. I recommend the 3/4" width, but 1" is also acceptible.
2) what to wrap. Don't bother with the top and bottom coils; protect the 2nd/3rd coils in from smacking each other.
So, in other words, skip the top and bottom coils, and wrap the next 1 and a half to 2 coils. The reason for doing this is to isolate the coils enough to prevent a noise when the springs touch.
3) dust boots, bushings, and bearings. It's my recommendation to replace all these components when you change your suspension.
The bushings on the rear: there are 2 bushings. The front strut mount bearings are 2 pieces (1 per side) that should also be replaced. The dust boots should also be replaced, but I recommend when using KYB AGX to use the KYB boots.
Old Sep 2, 2002 | 01:29 PM
RI-Max's Avatar
so what do u think i can use the shop air hose??? to do that??? casue its pretty thick. the only thing im gonna replace is the dust boots and when the bearing goes etc i'll replace that thanx anyway
thanx lime
Old Sep 2, 2002 | 01:59 PM
Lime's Avatar
Shop hose, as in for the air tools? That would be way too thick....
I've done a lot of suspension installs; those rear bushings are cheap so I would order them if I were you. I can get you part numbers if you need them.
www.cattman.com has the KYB dust boots. If you don't order these you have to cut the bump stops.
Old Sep 2, 2002 | 02:15 PM
RI-Max's Avatar
which rear bushings??? my car has 132,100 on it so i'll problay need it give me the part # the shop air hose is 2 thick? what if i cut it down the middle and slide it ova the 2.5 coils from the top??
Old Sep 2, 2002 | 02:16 PM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
We've got 3 or more guys with sprints in our metroplex, none of us have ours wrapped and we don't have spring impact noises. It's not a big deal with these springs. For sure though, trim your bumpstops like sprint says. Too much trimming leads to rubbing. Not enough leads to how my car is... full stiff all the damn time.
Old Sep 2, 2002 | 02:48 PM
RI-Max's Avatar
well how long have u guys had them on for???? and im gonna order the dust boots from cattman anyone have any idiea how long it would take to come in???
Old Sep 2, 2002 | 06:18 PM
turbomax97's Avatar
i've had my setup for ~ 5 months now........ my friend has had em probably 8 + months.
Old Sep 2, 2002 | 06:49 PM
KWheelzSB's Avatar
Shop air hose is DEFINITELY TOO THICK. I agree on this. Anyone who has done a Max spring install will tell you this. If you insist on using compressed air hose, you'll have your suspension apart and be scrambling for an alternative, trust me. Go with the spiral wire-wrap.
Do some searching, btw - suspension is about the most beaten-to-death dead horse on this whole forum. There's loads of info., advice & how-to's on it.
Best of luck!
Old Sep 2, 2002 | 07:33 PM
RI-Max's Avatar
trust me i searched and i was still lost but im much happier now thanx guys
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
knight_yyz
Nov 1, 2015 01:34 PM
Stagnet04
Oct 11, 2015 08:16 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
