shaving door handles? about door pop kits
Old Sep 3, 2002 | 09:30 AM
euromaxima's Avatar
What brand of door pop kit should i get....or what are some sites i can order them from....i seen autoloc...is this good?
thanks
Brandon
Old Sep 3, 2002 | 09:45 AM
max1ma97se's Avatar
get the 35lb kit at slickcar.com i have it and it is high quality the wires are thick so you dont have to worry about electrcity problems like those other crappy kits you buy at performance shops. need any pointers on install email or pm me
Old Sep 3, 2002 | 10:02 AM
thnikkamax's Avatar
Ludicrous Speed
You have one awesome ride man... So all doors have the door poppers, but does only one of them open with a remote, or can you pick a door to pop open, open all of them at the same time, only the front 2, etc.. ?
Old Sep 3, 2002 | 11:17 AM
euromaxima's Avatar
is it the one that 50 bucks each or what which one is it?
thanks
Brandon
Old Sep 3, 2002 | 12:24 PM
max1ma97se's Avatar
get the
(1) 9 Channel High Power Shaved Door Handle Kit- so you can hoke each door up to a button with one button to spare, has soleniods for front doors
(4) Amenity Stainless and Aluminum Door Popper (DP-3) - these actually push the door out about 5 inches
(2) 35 Pound Solenoid for Shaved Door Handles(with Hardware) (SIL35K)-for your back doors
Old Sep 3, 2002 | 01:03 PM
euromaxima's Avatar
get the
it says it controls the front windows can you roll them up and down with the remote button on your key chain? and the Amenity Stainless and Aluminum Door Popper (DP-3) - these actually push the door out about 5 inches ...will i need this for the front or rear ....i don't care about opening the rear just the front...i can reach arond if i want the rear to open...thanks for your help
Brandon
Old Sep 3, 2002 | 01:06 PM
Jason R's Avatar
aka UNCDooD
i want my ride shaved someday. so, i'm kinda curious about how much this costs and how hard it is to install? thanks for any info.
Old Sep 3, 2002 | 01:25 PM
meccanoble's Avatar
Sports Button FTW
Fluorescent light cover.... 6 dollars
Box-cutters...... 3 dollars
Heat gun....... $30 plus S&H
Showing a ricer your custom Red/White tails from 8 car-lengths ahead @ 110MPH...........Priceless
There are some things a V6 can't beat, but for everything else there's MAXIMA
hahahaah you have one of the best worded sigs i have ever seen, i thought mine was nice but yours is
Old Sep 3, 2002 | 04:33 PM
max1ma97se's Avatar
Brandon
alright you need the 9 or 7 channel kit because you need the relays and computer brain so you can have the Solenoids open the door for you with the remote. the Solenoid goes in each door and pulls on the metal rod inside the door that opens the door. (think of the solenoid as a hand pulling on the handle but cant push out the door) the actual door popper is the Aluminum Door Popper that is spring loaded that pushes the door out. since you only need the front, you just need to get the 7 channel kit and 2 door poppers. install is a b1tch you have to mount the giant solenoids in the inside bottom corner of the door (and keep clearance for the window) and run the metal wire to the metal rod that opens the door. run wires and relays mount the brain. if you live around me my friend does the install for 2 bills
Old Sep 3, 2002 | 04:46 PM
nadir_s's Avatar
vicodin ... gift of life
so... what happens when u accidently leave ure lights on and ure battery dies?? How do u pop the hood if the doors can't pop?? any "secret" latch or something to open a door?
Old Sep 3, 2002 | 04:58 PM
max1ma97se's Avatar
well takes power to open the door thats why i always check my lights and make sure i have my keys in my hand before i leave the car because it would really sux to brake my window unless i can find a kid to climb threw my skihole in the trunk
DBear
Sep 14, 2015 08:33 PM
Krazzespiinz
Sep 13, 2015 07:10 AM
Vequity
Sep 10, 2015 05:26 AM
rbaker100
Sep 6, 2015 02:46 PM
Hailstatejig
Sep 2, 2015 06:52 AM
