Can I put a jack here?
Old Sep 4, 2002 | 01:43 PM
Bluebird's Avatar
I am Roid Rage
I usually jack my car up with one jack under each wheel (A-arm specifically) but I am tempted to jack my car up underneath that black metal frame piece directly in the middle of the car (it runs from front to back directly underneath the engine). Although I'm scared to have it bend with the weight of the car on it. Does anybody else use this jack point. Reason I'm asking is cause I want to bring a seperate pair of wheels/tires to the track Friday and only want to bring one jack for changing them.
Old Sep 4, 2002 | 01:53 PM
sil SE's Avatar
what are the best points anyway guyS? i use the reinforced metal behind the "fin" along the sides under the doors..is that ok"?
Old Sep 4, 2002 | 01:57 PM
SupermaxGxe's Avatar
Re: Can I put a jack here?
Whenever I change the oil on my car I jack it up from the front, right in the middle. Its basically under the engine. I hasn't hurt my car yet.
Old Sep 4, 2002 | 02:04 PM
jdmmax's Avatar
i jack my car up with the cross member. look under the front of the car you will see a black bar. with a little bump thingy i have that bumo sitting right in the cup on my jack.
Old Sep 4, 2002 | 02:10 PM
Bluebird's Avatar
I am Roid Rage
I'm pretty sure we're talking about the same thing. I think it has like 3 ridges in it.
Old Sep 4, 2002 | 02:36 PM
syc's Avatar
syc
how about the rear? I know the places for jacking up the front. but the rear is kind of wierd for me. I had to put some wood at the rear "fin" under the door for the lift machine.
Old Sep 4, 2002 | 02:38 PM
Redmax's Avatar
Redlinemax Owner
there are 4 jackpoints under the car they are all part of that line that has the 3 ridges in it under the car on the sides. You will see a section where the line breaks twice. put your jack there to lift the car. those are made to jack the care up. Actually hydraulic jacks bassically latch in there perfectly.
Old Sep 4, 2002 | 02:46 PM
sil SE's Avatar
what about floorjack? where do you put the "cup"? what im sayin is i use the reinforced flat metal surface right behind the "fin" by the "ridges" .....wow lots of "in quotes"
Old Sep 4, 2002 | 04:20 PM
thebigsadler's Avatar
UM NO!!!.. that's not a jacking point.. at all.. it's there for the stock jack and the stock jack only and it's poor for even that..
there are upside down bell shaped metal pieces behind the wheel and in a little for the front.. and in the rear use the frame..
Old Sep 4, 2002 | 04:43 PM
Mad Dhan's Avatar
i second that, that is what i used.
Old Sep 4, 2002 | 04:50 PM
99MaxOnDubsSE's Avatar
Ya know..... i was thinking the same thing but you said it before me. i used to use my floor jack on the side of the car where there are the two little indentions...... yeah...... my s***'s all bent up now. it's really hard to bend it back too... yeah...
Ben
Old Sep 4, 2002 | 05:17 PM
sil SE's Avatar
so, uh , er, is my point safe? behind the ridge on the metal where its solid?
Old Sep 4, 2002 | 08:44 PM
uh, er, well, it's never folded like the side part.... so i guess it's the best place we've found so far.
Ben
jsmith24
Feb 1, 2016 12:35 AM
220k+ A32
Sep 23, 2015 03:38 PM
homewrecker
Sep 23, 2015 03:41 AM
alahjahwan09
18
Sep 21, 2015 09:12 PM
14GmMax
Sep 19, 2015 11:32 PM
