1995 Maxima Blower Not Working at low speed.
Old Sep 4, 2002 | 03:32 PM
str8fromegypt's Avatar
I have a 1995 Maxima w/ 96K miles on it. I was driving home from work with the fan at 2 and AC on and all of a suden no air. I said huh? Must be fuse. So I checked and replaced all fuses still not go. So I tried fan on 1. Still no go. So I cranked it up and it worked. What the hell is going on. It works fine on level fan 4 but nothing else. An i hear the AC coming on from the off to fan 1 level transition but fan does not come on till #4 level.
HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!
Old Sep 4, 2002 | 03:39 PM
JeffesonM's Avatar
living out of a maxima...
FAQ
Old Sep 4, 2002 | 04:28 PM
Originally posted by JeffesonM
FAQ
There is no info the FAQ's.
Old Sep 4, 2002 | 04:37 PM
max808's Avatar
Blower Motor Resistor
It sounds like your resistor is not working. The resistor allows 1-3 fan speeds to work and it is off when level 4 fan speed is selected.
Go to:
http://forums.maxima.org/showthread....5&pagenumber=5
Look for subject:
Why does my A/C only work on fan speed 4?
Good Luck!
Old Sep 4, 2002 | 04:44 PM
MaineMax's Avatar
you need a new Blower Motor Resistor Block. It costs about $35.00 at your Nissan dealer. It's located behind your glove box twords the middle of the car. Easy to replace, its held in by 2 screws. Its easier to locate once you see what the part looks like, the worse part is hanging upside down for 10 minutes while you fix it. I replaced mine a few weeks ago, simple job.
Old Sep 4, 2002 | 04:56 PM
mzmtg's Avatar
Minister of Silly Walks
I'll pretend you didnt say that...
Old Sep 4, 2002 | 04:57 PM
Re: Blower Motor Resistor
Go to:
Look for subject:
Good Luck!
Thank You very very much I will try that.
Ahmed
Team STILLEN
Aug 10, 2015 04:29 PM
kirkhilles
Aug 8, 2015 10:53 AM
kenc15
Aug 5, 2015 08:29 AM
RealityCheck
Aug 5, 2015 06:18 AM
silver_i35
Aug 3, 2015 11:20 PM
