where to tap for gauge lighting and power?
Old Sep 4, 2002 | 06:17 PM
Cumalot's Avatar
I know the blue wire on the dimmer switch is one where you can splice into for the gauge to light up. Anywhere else? I got three gauges that I currently have tap into the dimmer switch wire. Too many I would think. My fuses keep going out. Also, where else besides the cig. lighter wire where I can tap for a 12v power? Again, I got a few wires tap into the same wire, not good I think. Anywhere else I can try?
Old Sep 4, 2002 | 07:01 PM
ny96max's Avatar
for the illumination, i tapped into the bulb under the shift ****. Make sure you run both (+) and (-) off the light, or else you wont have the dimmer control from the dimmer switch.
For the power to the gauges, i went right off the main ignition harness with an inline fuse(15amp). If you want i'll e-mail you tommorow the color wire to look for under there
Ant
Old Sep 4, 2002 | 09:08 PM
1MAX2NV's Avatar
I think he's already over loading the dimmer switch circuit with over 3 gauges. I got the +12v light for my gauges off the headlight switch. I used a relay. They come on with the rest of the dash, but does not dim via the dimmer switch. I got the main +12V off the ignition switch. I used a relay on it too. By using relays, I can pretty much run as many gauges as I want without worrying about overloading OEM circuits.
Ant
Old Sep 4, 2002 | 10:31 PM
Cumalot's Avatar
Relays? Thanks. Hm...wonder why I haven't thought of that.
Old Sep 5, 2002 | 08:20 AM
hokiemax's Avatar
Could you explain in more detail what a relay does? I just bought a used automater full sweep FP gauge. (carbon fiber series). Does that come with a relay too? if not, where can I get one?
Old Sep 5, 2002 | 03:44 PM
1MAX2NV's Avatar
Search with web for SPDT relay. You are basically using low amp power draw to turn on high amp power supply. It's like your nitrous solenoid relay. All your main +12 power supply to soleniods do not feed to the arm switch right? The arm switch provides the low amp power signal to the main relay. The relay clicks and turns on the +12V supply to the soleniods.
xUNIxPanther
Dec 6, 2020 09:08 PM
JRod28
Feb 4, 2016 11:07 AM
magneto112
Sep 10, 2015 12:52 AM
JMag90
Aug 25, 2015 09:17 AM
kjm900r
Aug 5, 2015 07:14 AM
