Howto on 3 gauges under radio
Old Sep 5, 2002 | 11:10 AM
96bstdSE's Avatar
Does anyone have any info on howto do the 3 gauge setup for underneath the radio where the empty compartment is on a 96 SE (should be same on all 4th gens)
-or know of anyone that has done this?? I've seen a few pictures.
Old Sep 5, 2002 | 11:13 AM
sinewave's Avatar
PM MardiGrasMax. He's done a nice setup on his '98.
Old Sep 5, 2002 | 11:57 AM
clee130's Avatar
theblue has that setup also.
Old Sep 5, 2002 | 12:05 PM
BBaker025's Avatar
Im looking into doing this someday. Maybe there is a comapny that just sells single din gauge pods. Post if u got any ideas, im really interested!
Old Sep 5, 2002 | 12:41 PM
Chunger's Avatar
My other car is a Hybrid
http://www.hksusa.com/products/?id=660
Old Sep 5, 2002 | 07:52 PM
Quack 2x's Avatar
Re: Howto on 3 gauges under radio
If you mean the single DIN space under the radio, you can also take a piece of ABS plastic, plexi, or other material and cut it to fit the panel. I don't know if three gauges will fit, but I know two AutoMeter gauges (smaller size) will fit easily. You can hold the panel in place with L brackets to the original brackets, or just velcro it if you plan on removing it often.
If you have 2 DIN units, you can use the third pocket under the DIN spaces as well. Gauges may not flush mount all the way inside, so the trim rings (depending on the size of the gauge) may stick out and look like a rim around the gauge.
If you have access to a shop tools, you could even use aluminum (easy to cut and bend to line up with the mounting brackets). Also easy to drill out for the holes. I painted the panel black so it flushes with the rest of the dash.
In the third slot, you can fit two autometer gauges and one or two duckbill switches. Don't make the switches for anything important, since it is a long reach if you're short like me.
Hope this helps,
Quack2x
Old Sep 5, 2002 | 08:06 PM
1MAX2NV's Avatar
Something like this
Old Jul 20, 2003 | 04:48 PM
speedemn's Avatar
Is that the stock double din height or did you make it "taller"? I would like to stick in a single din deck (Alpine) and three 2 1/16" gauges. Would that be possible? (I assume that single din decks are all standard height - 2")
Originally posted by 1MAX2NV
Something like this
Old Jul 20, 2003 | 04:52 PM
speedemn's Avatar
Those pockets say that they will take 42mm or 46mm gauges... the only gauges I've seen are 52mm (2 1/16") or larger... how are you guys using those pockets for these gauges?
Old Jul 20, 2003 | 04:53 PM
Chunger's Avatar
Dremel...
Old Jul 20, 2003 | 05:07 PM
KMax2988's Avatar
Dremel...
Quick question, where'd you guys buy the HKS gauge panels from?
Old Jul 20, 2003 | 07:54 PM
Battle Max's Avatar
Uhh Im going to be ordering one of these first thing Monday morning thanks Chung But one question which one do i get Type A or B
Old Jul 20, 2003 | 07:58 PM
Battle Max's Avatar
uhh nevermind i figured it out...im getting away from the basic things like reading what the description says..
Old Jul 20, 2003 | 11:24 PM
Chunger's Avatar
Jon, I was gonna tell you "the one that is OUT OF STOCK" - "B"
"A" hold just one gauge and 2 1/4DIN HKS electronic controllers.
I bought them from HKS website directly.
Old Jul 21, 2003 | 04:46 PM
Battle Max's Avatar
any pics of the set up Chung????
Old Jul 21, 2003 | 05:20 PM
Chunger's Avatar
I'll take one tonight along with with my new HU too... LOL
Here's the NEW one:
Old Jul 22, 2003 | 04:25 PM
Battle Max's Avatar
wow that really is nice ill be pming you with questions once i get it in from HKS...
Old Jul 22, 2003 | 04:38 PM
ejj's Avatar
ejj
http://www.ericj.org/maxima/img/guages3.jpg
That's the HKS panel. I did a crappy job with the dremel.
gavin68
Sep 18, 2021 12:36 PM
Miket2006
Mar 1, 2021 03:55 AM
chisam14
Nov 6, 2018 08:56 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
