Car will not start...just backfire...help needed
Old Sep 8, 2002 | 10:02 PM
Dahnryman's Avatar
car was running fine stopped for gas at QT......dead
checked the ecu code....04/01....came bake intake Air temp sensor...
why would that make my car not start and does anyone know if it serves any other purpose....
Any ideas...anyone had this problem....
i am starting to hate my max....
Old Sep 8, 2002 | 11:30 PM
KSU1998's Avatar
Your car is treating you bad...
and here we were talking about getting together at the track....guess you may be out again..?
hope it is a quick fix.
D
Old Sep 9, 2002 | 05:57 AM
njmaxseltd's Avatar
I bet either a cam or crank position sensor failed. Your spark timing is off, thats why the back fire.
Your ECU may not be picking up the failure because the car isn't running and it can't "watch" the sensor. Had a similar problem with an I30 which had a no start condition, but no ECU codes. Turned out to be a crank sensor (POS).
The car to be hook onto a scan tool and all the readings, live, were watched. No signal was present from that sensor.
Strange how the ECU can pick up a problem while your car is running, but if it's not running and something goes bad, over night lets say... the ECU sometimes can't see what's wrong.
Old Sep 9, 2002 | 07:08 AM
Dahnryman's Avatar
ok
i will check that out and see if thats it....
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
TonyJr
Aug 20, 2015 12:14 AM
MikesChevelle
Aug 9, 2015 11:50 AM
laparka66
Aug 6, 2015 09:36 AM
