power window problem
Old Sep 10, 2002 | 03:47 PM
bang4thebuck's Avatar
I have a 95 SE. The power window in the right front stopped operating. Upon investigation, I discovered a rubber 'gear'bushing which has separated, center from outer portion. This gear/bushing is black rubber and is the coupling between the window motor shaft and the wheel which the window drive cable is rapped around.
Just wondering if I can buy just the gear/bushing part or would I need to buy the whole motor assembly and where would I purchase these parts ?
Thanks for your help, b4b
Old Sep 10, 2002 | 05:18 PM
69CHARGER_RT's Avatar
http://www.oem-car-parts.com
Old Sep 10, 2002 | 06:46 PM
D1NOnly34's Avatar
I also have a problem
I also have a 95 SE, lately my front drivers side windows goes up real slow...goes down pretty much at normal speed, but when puting it up its always last of all windows...anyone know what could be the problem?
Old Sep 11, 2002 | 06:46 AM
After doing a search before my original window posting, I did a search and there are a couple of suggestions....
- lubricate the window track/seal on the inside of the window opening in which the window rides. This is very easy. No disassembly required. Use lithium grease ? Check that with somebody who knows more than me. This might solve that problem with very little effort.
- If the window is still slow, check the track guide (this is not the official name) in which the window bracket rides in. You will have to remove the door panel. Some effort but the Max door panels come off pretty easy. Clean and lubricate.
Old Sep 11, 2002 | 06:55 AM
maximised's Avatar
Re: I also have a problem
yeah mine is doing the same now too...
Old Sep 11, 2002 | 10:44 AM
MIXXMAX's Avatar
Also, what you could do is take the whole window out of the door. It's only held onto a bracket with two bolts. Be VERY careful you don't break the glass. Then you can ALIGN and LUBRICATE the rubber molding where the window glides on. Sometimes, after many times of use, the window channel (the black molding strip) will work its way out of alignment, causing the glass to "ride" prematurely. For lubrication, use small amounts of lithium grease on the inside of the track. If you put too much on, then the grease will show up on your window each time you raise and lower the window. This worked for me like a charm, when I was experiencing these same type of problems.
Old Nov 16, 2002 | 09:26 AM
MystiWink's Avatar
Did u ever get your window to work right>> Im having the same problem.
Old Nov 16, 2002 | 10:25 AM
daroknessmonsto
mine as well
my drivers side is the slowest of them all as well.
Old Nov 17, 2002 | 05:08 PM
Rickalodeon's Avatar
I'm having the same driver's side window problem. I read, in other posts, that lubricating the window seal (along the top of the door panel) with a "dry silicone" - so as not to smear the window - should solve the problem. Looked high and low for "dry silicone" and could only find STP Silicone Spray that is supposed to dry fast. Will try it as soon as the rain stops.
Old Nov 17, 2002 | 05:26 PM
MystiWink's Avatar
I have used that on the track. but not on the seals yet, do u mean the black track along the inside of your car or out side?. Im getting the same rain as u I think even if we are 3 states apart.
Old Nov 18, 2002 | 03:53 AM
I believe the posts were referring to the track that your elbow would sit on if you were hanging it out the open window during a summer cruise. I'll be trying the inside first...If it streaks, I can deal with it a little easier from the inside. If it doesn't streak, I'll do the outside as well.
Old Nov 18, 2002 | 05:13 AM
MystiWink's Avatar
ROTFL.. no the metal track on the inside of the door frame that slides up and down on by the motor.
Old Nov 18, 2002 | 07:13 AM
I shouldn't have said track...I should have repeated my previous post. I'm not referring to window track or weatherstrip or brackets. Rather, I'm referring to the seal that prevents [some] water and other debris from getting down into the door panel. This has been the source of several posts discussing slow and squeaking windows.
Old Nov 18, 2002 | 07:47 AM
MystiWink's Avatar
Im sorry I will try that today and see what happens.
lowpost99
Oct 26, 2025 06:53 PM
The Frye
Sep 2, 2021 11:03 AM
The Frye
Feb 3, 2019 08:34 AM
trungg86
Sep 4, 2015 04:58 AM
