Easy way to remove rotors - correction
Old Sep 12, 2002 | 05:14 PM
karguy's Avatar
I gave you some bad info! The 2 40mm M10x1.25 bolts are used to remove the front rotors. You need 2 40mm M8x1.25 bolts to remove the rear rotors. You just screw the bolts into the rotor, alternately tightening the bolts until the rotor is loosened. Sorry!
Old Sep 12, 2002 | 07:33 PM
dmbmaxima2k2's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
Re: Easy way to remove rotors - correction
take breaker bar, slam rotor in fit of rage till it finally loosens. hmmm maybe that was just me that did it like that.
Old Sep 12, 2002 | 08:03 PM
Kashoggio's Avatar
is it me, or this is a simple job. All the break job consists of is 4 blots and new pads. And maybe new rotors is they are that bad. Yes you should bleed the brakes everytime you do a break job but no one does that.
Old Sep 12, 2002 | 09:53 PM
SLC I30t's Avatar
wow you must have been tired. When doing a BRAKE job I only take 2 BOLTS off to change my pads and 4 if I had to replace the rotor. But to take off the rotor to replace it I would just use a 2lb sledge to the back of it.
Old Sep 13, 2002 | 06:26 AM
njmaxseltd's Avatar
Not only should you bleed them, but you actually should FLUSH the system. Brake fluid absorbs moisture and needs to be changed. I make a habbit of flushing my brake fluid every time I do a brake job. It's cheap insurance against a failure due to contamination. This is especially important if you have ABS.
litch
123
Jan 4, 2024 07:01 PM
Socalstillen
Sep 26, 2015 12:01 PM
Noela
Sep 26, 2015 08:22 AM
worldwiderecognized
Sep 24, 2015 06:56 PM
