doing agx install tomoro...how tight these bolts need to be?
Old Sep 12, 2002 | 08:37 PM
MaximaPower's Avatar
newbie here ...well i'm doing an H&R and AGX install tomoro. i need help on how tight the bolts and nuts need to be. ie the lower bolts on the shocks/struts
and how do i read the specs?
if it's in ft-lbs which is the torque right?
well wats psi? is it lbs?
my little impact wrench has a max of 260ft lbs. and 90 psi...will this do?
thanks!
Old Sep 12, 2002 | 08:41 PM
syc's Avatar
syc
Re: doing agx install tomoro...how tight these bolts need to be
thanks!
you can search or buy a haynes.
ft-lbs is for torque measurement (in lb per ft). psi is for pressure measurement ( lbs per square inch). when doing the bolt, all you need is the torque spec.
Old Sep 12, 2002 | 09:18 PM
Re: Re: doing agx install tomoro...how tight these bolts need to be
looking at my haynes manual right now and see that the rear upper mounting nuts are to be tightened to 144 to 192 in-lbs and that the rear piston rod nut is to be tightened to 156 to 204 in-lbs...which is PSI right? so that means my weak little impact wrench wont do
Old Sep 12, 2002 | 09:23 PM
spiff56747's Avatar
no, i think its talking about torque
although i've never seen inch-pounds before.
basically divide each number by 12, and you'll get foot-pounds
Old Sep 13, 2002 | 05:01 AM
r u sure? cus for the rear upper nuts it says 144-192 in-lbs(that's wat the haynes manual says)...if i divide 192 by 12 it's only 16 ft-lbs...is that a little low?
thanks for replies
Old Sep 13, 2002 | 06:13 AM
njmaxseltd's Avatar
thanks for replies
Thats correct, check your PM's I gave you some more specs.
Tom
lowpost99
Oct 26, 2025 06:53 PM
spazma7ik
Jan 12, 2017 09:38 PM
The Wizard
24
Oct 1, 2015 08:47 PM
ag90fox
Sep 9, 2015 12:22 PM
Maxboy23
Sep 4, 2015 06:04 PM
