How do I know if I have an exhaust leak?
Old Sep 13, 2002 | 03:13 PM
240sxxx's Avatar
I recently installed a magnaflow muffler, the place where the mid pipe connects to the extension that goes to the muffler seems be sort of loose....... when I noticed it, right away I thought that maybe I also have an exhaust leak because of the looseness.....
so how can I find out if its leaking or not??
thanx in advance
Old Sep 13, 2002 | 03:21 PM
Linkage23's Avatar
Depends
Did you install your muffler yourself or did a shop do it? Personally I would take it in to a Midas or Minekee shope to have them test to see if there is indeed a leak. It should only cost about $20-30 so that shouldn't be too much of an issue. Sorry if this doesn't help but that's all I got...Word.
-King Ryan-
Old Sep 13, 2002 | 03:29 PM
Y2KSESteve's Avatar
You could fire up your engine and put your hand around the connection to see if there is a leak. If there is you should know. Thats what I did anyway.
Old Sep 13, 2002 | 03:35 PM
Toolrocks's Avatar
While the engine is idling, have someone cover the exhaust tip w/ their shoe while you listen to the questionable joint. If it is leaking you should hear air escaping from the joint. Also, if it's leaking, you should also be able to feel air escaping through the seam as well. Good luck.
Old Sep 13, 2002 | 04:28 PM
carnal_c30's Avatar
Former Sponsor
you can also hear a buzzing sound often as the gaskets vibrate it happens when you're on the gas you can hear it if you drive next to a median or some other solid structure
Old Sep 13, 2002 | 05:27 PM
nadir_s's Avatar
vicodin ... gift of life
If you have a leak in your exhaust your car would sound obnoxiously loud and ghetto
Old Sep 13, 2002 | 06:06 PM
240sxxx's Avatar
I had a shop do the install for me...... and as someone mentioned when I put my hand around the connection there seems to be no air escaping and no werid sound so I guess its not leaking
thanx for the help guys....
Old Sep 13, 2002 | 11:09 PM
Y2KSESteve's Avatar
My car's already obnoxiously loud already oh well. I like it!
Old Sep 14, 2002 | 05:15 AM
carnal_c30's Avatar
Former Sponsor
depends on how bad of a leak you have... my car wasnt any louder but i had an exhaust leak i could hear it... crushed crush seal on the y-pipe boltimg up to the manifold... small leak but it was audiblle i hated that damn buzzing sound
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Justin Kroll
Oct 1, 2015 07:03 PM
09maxshawn11
Sep 30, 2015 10:28 AM
Socalstillen
Sep 26, 2015 12:01 PM
