Attaching aftermarket fogs?
Old Sep 14, 2002 | 01:01 AM
Speebs's Avatar
I aim to misbehave.
What's the best way to attach aftermarket fogs? I am putting them below the grille, because I don't want to cut apart my bumper, but I can't figure out a good way to secure them. I can't really drill into the metal bumper...
Any help is much appreciated!!
Thanks,
Doug
Old Sep 14, 2002 | 05:28 AM
carnal_c30's Avatar
Former Sponsor
Re: Attaching aftermarket fogs?
Thanks,
Doug
double sided tape and c-clamp
Old Sep 14, 2002 | 08:26 AM
Speebs's Avatar
I aim to misbehave.
hmmm...
I am very afraid to use double-sided tape. Are there any other options?
Old Sep 14, 2002 | 11:03 AM
SamMan23's Avatar
I'm doing the same thing. I'm not sure where you attach that c-clamp.
Old Sep 14, 2002 | 06:15 PM
MIXXMAX's Avatar
Thanks,
Doug
On my '95, I mounted them (with bolts) on the opening ends on each corner on the bottom part (in the center portion) of the grill. I bolted them on the "side-separator" (sorry, I don't any other word to explain this). I used the round-type aftermarket fogs. But, since I wrecked the car last year, the body shop mounted them from underneath since they had the bumper of the car. But, for the most part, buy the round type and drill a hole (for the mounting bolt) into the side-seperator and you'll be fine.
Old Sep 14, 2002 | 06:22 PM
teraspeed's Avatar
Re: hmmm...
It takes a lot of courage, but just remove the backing, stick it on and run like hell. Once it's attached, it doesn't seem so scary anymore. It's like turning off your night light for the first time.
Old Sep 14, 2002 | 07:00 PM
carnal_c30's Avatar
Former Sponsor
as long as you prep the surface and use really good tape like 3m it will last
use some kind of clamp if you can just for added security and watch for people who like to jack fogs
Old Sep 14, 2002 | 07:26 PM
Speebs's Avatar
I aim to misbehave.
Re: Re: Attaching aftermarket fogs?
What did you bolt them into? I can't drill holes into the metal bumper...
Old Sep 15, 2002 | 09:10 PM
ThurzNite's Avatar
Re: Re: hmmm...
yeah...then i came around your neighborhood and ripped them right off...wires and all...
Jae
Old Sep 16, 2002 | 07:21 PM
JPMax's Avatar
What's next!?..
I just put my front end up on some ramps crawled under and drilled a hole for each one into the metal part of the bumper from underneath.
Not that hard if you have a strong drill. Preferably corded.
mpbclutch33
Dec 26, 2015 11:11 AM
trsandrew
Oct 25, 2015 02:47 PM
Calabar
Oct 5, 2015 09:57 PM
bigfrank
Oct 1, 2015 12:51 PM
