I noticed both of my fogs quit working. Both at the same time. About a month ago i put hyperwhite bulbs in. All my headlights and things are fine. Would that be the problem? Is there a fuse for the foglights anywhere?
I think there is a fuse - I'm not sure what it's labeled. Just check em all if it isn't clearly labeled. There is also a relay in the engine compartment you might want to check as a last resort. Also, not to insult your intelligence but you're sure the switch on the stalk is set to on right?
Good luck.
Good luck.Senior Member
upgrade your fuse. I belive the stock fuse rating is 10amp, if so throw in a 15amp. If its a 7.5amp throw in a 10amp. And yes youll be fine
Ant
Ant
Ok i seen a fuse labeled FR FOG in the box next to the battery, its not blown so thats not the problem. Guess ill look at that relay. It could be burnt bulbs but i just dont think both would go out at the same time, but i guess its possible.
Quote:
check out bulbs..put stock back in see if that works ...i had aftermarket ones that would burn out like that. i ended up w/piaa super plasma. but check that out.Originally posted by LeonBlackMax
check the bulbs. put original ones in just to check.Originally posted by LeonBlackMax
