Knock sensor error but still checks in spec?
Old Sep 15, 2002 | 07:47 PM
maximaking's Avatar
OK guys, I got the knowck sensor code from the ecu, did a search and found thhat the know sensor is tested by checking the resistance between the sensor and a known good ground. my reading was dead center of the range for spec. Im not sure if its a bad sensor or not. This seems to be a common problem, I got ~140k miles and I know that this wasn't a one time thing as the light came back on w/the same code after reseting it after a few hours. Could this be bad gas causing the problem? I always use name brand gas except for this time where I went to a small gas station in the country.
Todd
Old Sep 15, 2002 | 10:52 PM
munji's Avatar
Knock Sensor
I am not positicve if poor gasoline is the direct cause of the problem but I wouldn't be surprised if it were. I ran into a similar problem, I used 89 octane for awhile, got the 304, then switched to 92 which is the best we have in Kansas which is funked up since St. Louis has 93 but that is different story) Anyhow, I changed out my knock sensor after it blew codes at me and now all is well.....I recommend changing it and always running high octane.......
Old Sep 15, 2002 | 10:56 PM
chris j vurnis's Avatar
Change the knock sensor.
Even if it passes the resistance check, it could still be too sensitive over time.
Old Sep 16, 2002 | 05:07 AM
95Max's Avatar
Do you have only the knock sensor code?
Posible causes if only knock code:
1)The sensor
2)Running low octane gas
3)Bad gas
Once you get the "good" gas back in the tank clear the codes and see if the code comes back
Old Sep 16, 2002 | 08:58 AM
NmexMAX's Avatar
dot dot dot ...
My error code went away instantly after I changed it. Maybe the wiring harness.
Old Sep 16, 2002 | 10:01 AM
TooMAX's Avatar
Re: Knock sensor error but still checks in spec?
In addition to the other suggestions here, I'd also clean the two ground wires on the top/front of the manifold.
Old Sep 16, 2002 | 05:55 PM
eskim_77's Avatar
The engine light just came on with Knock Sensor 0304. Besides this, I have 0504 Automatic Transmission Control Unit, and 0705 EVAP Control Unit. How bad is replacing Knock Sensor? Is it difficult? Hard to reach? Expensive? I can't believe this is happening to my car because I have only 65K miles(1997), and 99%, I use Mobil and Exxon for gas. I can probably counts, I filled up with 89 gas less than 10 times. Anyway changing Knock sensor will cure one of problem, I guess. Do you have part number for knock sensor?
Thanks in advance.
Old Sep 16, 2002 | 07:21 PM
sinewave's Avatar
So why are you going to replace the knock sensor but not change the Automatic Transmission Control Unit, and EVAP Control Unit? You have an error code for each.
I wouldn't change ANYTHING without investigating further. Remember that the ECU is not TESTING sensors and telling you what's bad, it is just reporting what is being effected by a problem.
To me, three seemingly unrelated error codes indicate something else is going wrong. I would clean battery cables, ground connections, wiring harness connections, etc. For the wiring harness connectors, I would disconnect them one at a time, spray them with CRC Electronics cleaner and reconnect.
If you closely study FSM wiring and connection diagrams, I'll bet you will find at lest one connector that all three of these signal wires share. That's where I would concentrate my search.
mvm062
Nov 30, 2020 09:00 AM
Slamrod
Sep 3, 2015 07:38 PM
maximusrising
Sep 2, 2015 09:55 AM
A32goldylocks
Sep 2, 2015 06:39 AM
maxinout93
Aug 20, 2015 02:17 AM
