48 offset....will it work?
Old Sep 16, 2002 | 02:32 PM
ATmax99gle's Avatar
Is this wheel offset okay on a 99 max?
Just got a set of 17s. I told the shop that I needed something in the 38 - 45 offset range. Waited a month for these and they sent me a 48 offset.
Will it work or is it gonna stick out of the fender?
Need help yall!
Thanks.
Old Sep 16, 2002 | 02:39 PM
kushane's Avatar
Re: 48 offset....will it work?
Need help yall!
Thanks.
I can't fully answer that question, but your worry should be about the wheel recessed too deep in the fender and not sticking out. A higher offset means that the wheel will be set deeper inside the wheel well and not the other way around.
Old Sep 16, 2002 | 02:44 PM
theblue's Avatar
No way!!! and where did you get your numbers from? you should use a 35-40 offset. 45 will work but that would be the extreme most you would want to go. Your wheels will be tucked under and will cause rubbing
Old Sep 16, 2002 | 03:00 PM
dashingMax's Avatar
NO
NO...don't even think about it!
Old Sep 16, 2002 | 03:02 PM
Tifosi's Avatar
My 2k2 SE rims are 45mm offset and they look just fine and isn't tucked in much.
Tifosi
Old Sep 16, 2002 | 04:04 PM
I30tMikeD's Avatar
a 48mm offset is not the most ideal. 35-40 is optimal.
Old Sep 16, 2002 | 04:41 PM
capmaxima99's Avatar
Ok higher the numbers the more tucked in it would be. On my old maxima(99) I had the same rims I have on my 02 and there is no rubbing. The rims are 18-7.5 with a 45mm offset. I have seen with a 38 mm offset looks the best. Its flush with the body and etc... But the 48mm with work. If you want just get some 5-10mm spacers. There only about 40 bucks for all of them.
Chris
Old Sep 16, 2002 | 04:46 PM
theblue's Avatar
I have never seen anybody put 48s on a maxima - they won't fit well... 45 is pushing your luck (I know this first hand). and if you think spacers are safe then go for it...
Old Sep 16, 2002 | 04:50 PM
voltman's Avatar
Someone had +50 offset Lexus wheels. I believe he needed spacers.
Old Sep 16, 2002 | 07:18 PM
I30tMikeD's Avatar
How is 45mm pushing your luck? My stock wheels were 45mm. Look in your manuel, it says your stock offset.
Old Sep 16, 2002 | 07:23 PM
king's Avatar
have no idea, but just have it "rigd"
Old Sep 16, 2002 | 09:27 PM
ATmax99gle's Avatar
Yeah!
And probably a little bit of Black BBQ paint on them too, huh?
I guess I'm returning these wheels for the right offset. Ain't gonna try my luck on these.
Thanks to all that replied.
Old Sep 17, 2002 | 07:08 AM
theblue's Avatar
Yeah!
good man! you're making hte right choice
Old Dec 15, 2002 | 10:26 PM
sil SE's Avatar
bringing back an old thread
anyone running a +48 offset with 5mm spacer?
feedback please!
Old Dec 15, 2002 | 10:49 PM
1MAX2NV's Avatar
45mm on 7" wide wheels. But if you increase the width of the rims, the offset will need to change to be optimal.
Old Dec 15, 2002 | 11:32 PM
Nismo's Avatar
feedback please!
I am. I have 48mm 18x7.5 wheels with 5mm spacers so its now a 43mm offset. I only have the rear wheels on at this time because I dont have tires for the fronts and everything is fine. TurDz has 42mm offset wheels and he doesnt have any problems at all so I doubt 1mm more will affect anything. Just make shure you use the new longer wheel studs when you get spacers.
Old Dec 16, 2002 | 07:56 AM
sil SE's Avatar
5mm is the point where some say get the longer studs, some say you dont need to. so i'm confused there
maybe its more trouble than its worth buying a wheel that far off spec. darn
Old Dec 16, 2002 | 12:34 PM
Nismo's Avatar
I wouldnt even dare to ride on spacers without longer studs. H&R 5mm spacers come with the longer studs in the kit so its there for a reason.
mvm062
Nov 30, 2020 09:00 AM
kmitchel
Oct 30, 2015 10:12 AM
Maxima30
Sep 7, 2015 06:13 PM
iflexsteel
Sep 2, 2015 08:04 AM
Hailstatejig
Sep 2, 2015 06:52 AM
