NGK laser Plat Spark Plugs
Old Sep 19, 2002 | 06:06 AM
ssilva420's Avatar
Just though id give a heads up to you all that i got some NGK Laser Platinum plugs on ebay for 40.00 shipped.. Just keep your eyes open for them they pop up every once in a while.... also doen anyone knwo where to get them cheaper then that....
Old Sep 19, 2002 | 07:58 AM
amb4081's Avatar
Re: NGK laser Plat Spark Plugs
That is cheap...I paid around 65 or 70 bucks for a set of 6.
karguy's Avatar
The only place I have gotten a better price than $40.00 shipped was also on eBay. Like you said, you just need to keep looking and be patient!
Old Sep 19, 2002 | 08:55 AM
phenryiv1's Avatar
Mod her. Ate her.
What is the P/N or code that we need to look fo rto ensure that we get the right plugs? Also, who was the seller on eBay? Lastly, were the plugs listed under a search title that includes "maxima," or did you just search for NKG and then look for the correct P/N?
Old Sep 19, 2002 | 09:37 AM
ssilva420's Avatar
i ran a search on the org. to see what plugs were perfered by maxima drivers.. then i ran a search on ebay for the NGK Laser Plat plugs.. and there was a set on there that specificly said 95-99 maxima.. so i bought them at the buy it now price...
Old Sep 19, 2002 | 09:58 AM
P()()RB@Y's Avatar
Wy does everyone use Platinum plugs?Dont NGK Coppers spark better.The Platinum plugs just last 60k miles while the coppers last like 25k.
Old Sep 19, 2002 | 11:10 AM
phenryiv1's Avatar
Mod her. Ate her.
Originally posted by P()()RB@Y
Wy does everyone use Platinum plugs? Dont NGK Coppers spark better. The Platinum plugs just last 60k miles while the coppers last like 25k.
Do you mean 6K, not 60K? I thought that people preferred coppers as well.
Old Sep 19, 2002 | 12:09 PM
ssilva420's Avatar
People who run nitros seem to preferre the copper plugs due to the larger spark that is created... thats really the only reason.. it makes a larger explosion of power
Old Sep 19, 2002 | 01:01 PM
Kevin Wong's Avatar
My friend uses copper in his Type-R, and says other dyno'd higher power all around the RPM, but he says you have to change them every 8K on his Integra. I think if our plugs were as easy to access, I'd switch to copper. But those plugs by the intake manifold really suck. I'll stick with the platinums.
I was just wondering if those NGK Laser platinums are the same as the Nissan OEM plugs, or if the are something better.
Old Sep 19, 2002 | 01:07 PM
Jamsan's Avatar
changed my plugs the other day....i didnt really have a problem with the 3 behind the intake manifold, except for the one closest to the throttle body....grr that one ****ed me off .....and well, my strut bar wasnt helping much either.....i got NGK Lazer Plats at about $9.50 a piece at Advanced Auto, so all together I payed around $63, and thats inclding the price for a PCV valve i also bought...
Old Sep 19, 2002 | 01:16 PM
phenryiv1's Avatar
Mod her. Ate her.
What about NGK Iridiums? Better/worse/not worth the money?
Old Sep 19, 2002 | 01:22 PM
karguy's Avatar
OEM plug will have NGK PFRG5-11 on it. The NGK plug to use on our car is NGK PFR5G-11. They are the same plug!
Old Sep 19, 2002 | 01:25 PM
karguy's Avatar
In my personal experience the NGK Laser Platinum Plug is the 1 to use. The recommended NGK Plug is PFR5G-11 for 4th gen Max. In the long run they are the most cost effective!
Old Sep 19, 2002 | 01:28 PM
Chino's Avatar
Hey Jamsan, remember I had posted my times (still running 17s) for you to help. Could the spark plugs be the reason? I'm running 10k old Denso Platniums. Could this be my problem?
Old Sep 19, 2002 | 01:29 PM
karguy's Avatar
The new hybrid NGK Iridium is the way to go! Iridium center electrode with a Platinum ground electrode. So new I can't find any feed back on them. Why don't you try them and report on your results!
Old Sep 19, 2002 | 01:35 PM
karguy's Avatar
They were listed on eBay as 30 NGK Spark Plugs. I found out what they were (NGK PFRG5-11), I knew from previous research that they were the NGK Laser Platinum Plug for the 4th Gen. I got 30 NGK Laser Platinum Plugs for $ .38 cents each shipped. I put a set in my car and my daughter's car. Kept an additional set for my car and sold the rest.
Old Sep 19, 2002 | 01:44 PM
phenryiv1's Avatar
Mod her. Ate her.
They are about $70 a set. How is projected longevity on them, as compared to platinums? Can I run them as drop-in replacements, or do I need to change something else (wires, etc.) to run them?
Old Sep 19, 2002 | 01:49 PM
karguy's Avatar
I would call NGK Corporate Technical Support. I got their number off this site www.ngk.com when I called them. Sorry I lost their number.
Old Sep 19, 2002 | 02:56 PM
Jamsan's Avatar
very well might be....those things are HORRID....id change them out now now now....those screwed up one of my friend's coil packs
Old Sep 20, 2002 | 08:57 AM
Chino's Avatar
Which ones would YOU recommend?
Old Sep 21, 2002 | 06:20 AM
Blade_99SE's Avatar
Get the stock ngk platium plugs for the 4th gen. Also gap the at the higher end {.039 to .044} of the factory gap. I've gapped mine at .044 and my car has never run better. I also tried to index them. I pointed the open end of the ground toward the exhaust valves. Much better mileage, throttle response has improved, and my butt dyno says more power.
magiconthetire
Oct 26, 2015 09:03 PM
Need help
23
Oct 2, 2015 08:56 AM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
