Broken Studs
Old Sep 22, 2002 | 04:05 PM
C3nthusiast's Avatar
Broken Studs
I have 1 broken stud and possibly one cross thread stud all on one wheel. Should I be worried? How do you know when your wheel is about to fly off????? Will I have time to stop? hope so.....
Old Sep 22, 2002 | 04:46 PM
sryth's Avatar
Re: Broken Studs
I broke a wheel stud a week ago, and have put on over 500 miles since. I'm waiting on my slow *** Nissan dealership to get my new gas filler door back, so I figure I'll get the new stud/lug nut when I pick it up.
I don't know about running with 2 broken studs. Why not take a trip to the dealership and get new ones? They're only a couple of bucks a piece (~$3).
-Sryth...
__________________________________________________ ____________________________
'98 SE 5spd, Pebble Beige, PRCAI, Stillen Y, Stillen FSTB, ACT clutch.
Pacesetter STS to be installed this week!
Old Sep 22, 2002 | 04:55 PM
Capitone's Avatar
Better safe than sorry, you might as well pick up the studs and put them on when you can. With two studs having issues, you may begin to have problems with the other three. Same thing happened to me with two studs. Road home from the dealership after they tried to charge me like 80 bucks to fix it an looks like the ride back, bent two of the last three good ones.
Ramius83
PepBoys/Autozone carries our studs for less than a dollar a piece. I just broke two, I am replacing them tomorrow. I would not drive your car a lot until you do get the two studs. If you broke the two studs right next to each other, do not drive on it. But if you broke one opposite from the other, than you should be OK to drive a little. But because of two studs being broken, you may chew up your rim.
Old Sep 22, 2002 | 08:23 PM
ereet's Avatar
You will hear loud clunking sounds and feel crazy vibrations when your wheels are loose enough to fall off. I decided to try the stock lugnuts on my tantrums last year and within a week, I had to pull over and tighten them because they were finger loose. Stoooopid.
Old Sep 22, 2002 | 11:09 PM
Kanaka's Avatar
just go to nissan and get a few new studs. they're about 2 bucks each and are easy to replace. just take off wheel and i think the brake calliper and disk and hit the stud through. just pound it in with a hammer and it will come out. put the new one in and pull it tight with the lugnut. easy to do.
Old Sep 22, 2002 | 11:44 PM
sryth's Avatar
I don't even think you need to take anything off (except for the wheel of course).
-Sryth...
Old Sep 23, 2002 | 12:27 AM
Nealoc187's Avatar
SLOW
-Sryth...
No, you need to take the caliper and rotor off to bang the studs out.
Old Sep 23, 2002 | 12:46 AM
sryth's Avatar
Hmm... I just searched, and you're right! I thought I read somewhere that you didn't need to remove the rotor. Oh well. Here's a link to some instructions written by DBM: http://forums.maxima.org/showthread....870#post266870
-Sryth...
litch
123
Jan 4, 2024 07:01 PM
James92SE
142
Jan 2, 2024 09:23 AM
tarun900
19
Dec 20, 2021 06:57 PM
dcam0326
Sep 26, 2015 05:20 AM
Lowered_a33
Sep 10, 2015 09:41 PM
