Rear Brakes
Old Sep 25, 2002 | 07:41 PM
BCS's Avatar
BCS
Rear Brakes
I was replacing the brake pads both front and rear. The fronts were not problem but I couldn't get the rear caliper piston to retract. I tried using long nose pliers to rotate it but it would hardly move. Any suggestions
Old Sep 25, 2002 | 07:46 PM
Bags's Avatar
VG Ridah's Biatch Hoe
Re: Rear Brakes
a large "C" clamp to push the piston in
Old Sep 25, 2002 | 08:12 PM
tmkforever's Avatar
You've really gotta twist and push at the same time. Even when you do it correctly, it still takes a couple of minutes and a few rotations to get the piston all the way back into the caliper. Just keep tryin' at it with the needlenose. Good luck!
Old Sep 25, 2002 | 08:32 PM
BCS's Avatar
BCS
[Does Nissan or anyone else make a special tool to turn the piston while you are pushing it in.]
Old Sep 25, 2002 | 08:42 PM
tmkforever's Avatar
Yes.
Old Sep 25, 2002 | 11:08 PM
voltman's Avatar
Get a loaner disc brake tool kit for an auto parts store.
Old Sep 25, 2002 | 11:22 PM
karguy's Avatar
Yes, I bought 1 at Advance Auto. It fits 5 different sizes of rear brakes. A 3/8 in. extension and ratchet are used with it. With this tool it took me less than 15 seconds to have the caliper all the way in. It cost about $9.00 and is made by AmPro, part number T71921 and it comes with a Life Time Warranty. AmPro Tools Corp. is located in Cupertino, CA95014. It is called A Disc Brake Piston Remover.
mvm062
Nov 30, 2020 09:00 AM
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
homeyclaus
Sep 3, 2015 06:15 PM
A32goldylocks
Sep 2, 2015 06:39 AM
