replace computer?
Old Oct 1, 2002 | 09:49 PM
hbsprite's Avatar
replace computer?
I have a 96 GXE with 110K miles. I noticed that the radiator fans were not coming on. I tested both the fans by taking them out and connecting them to a 12V source, they worked fine. I checked all the relays and fuses associated and all were fine. I finally gave up and took the car to my trusted mechanic. He said that he traced the problem to the computer and that I need a new computer. Can anyone think of anything else that might be causing this? Thanks
Old Oct 1, 2002 | 09:53 PM
DaddyMac's Avatar
I really think it is a fuse/relay.
Old Oct 1, 2002 | 10:42 PM
hbsprite's Avatar
I personally checked all associated fuses/relays, and my mechanic double checked them. They are all fine.
Old Oct 1, 2002 | 10:55 PM
dwapenyi's Avatar
How about all the wiring harnesses associated with the fans? Maybe one of them is suspect.
DW
Old Oct 1, 2002 | 10:59 PM
hbsprite's Avatar
DW
We also checked the connections between the fuses and the fans, they were fine. The only thing we have left to check is the connection between the computer and the relays/fuses. If that checks out OK, I'm afraid I will have to replace the computer. My checkbook isn't looking forward to that
Old Oct 2, 2002 | 06:08 AM
Stephen Max's Avatar
You can find used ECUs in the $150 range. Do you have any friends you could do an ECU swap with first, just to verify that it is indeed an ECU problem?
Old Oct 2, 2002 | 12:30 PM
hbsprite's Avatar
Unfortunately I don't know anyone else with a Maxima that would be willing to let me swap computers with them. Where could I find a used computers that price? Is there anywhere I can look online, or should I try the local junkyards? Thanks
Old Oct 2, 2002 | 01:11 PM
mike_rose's Avatar
it sounds like a fuseable link to me. you can measure a broken one with just a thread of connection and still get the correct voltage but not enough amps to switch the relay on. i would really check the voltage drop on those before getting a new computer.
Old Oct 2, 2002 | 01:28 PM
That's the price that was quoted to me by a local junkyard. You can try car-part.com
PH98I30
29
Feb 10, 2025 12:03 PM
mvm062
Nov 30, 2020 09:00 AM
dvcamp
Sep 18, 2015 10:17 AM
Maxima30
Sep 7, 2015 06:13 PM
sdotcarter
Sep 2, 2015 09:53 PM
