Interesting Tire Wear Pattern....
Old Oct 5, 2002 | 05:34 AM
n2oMike's Avatar
I've recently started travelling a VERY crooked 25 mile road to work... and I do NOT drive slow.
The weird thing is, it's the INSIDE tire that is squealing around the turns... not the tire on the outside of the turn.
The car used to wear the tires very evenly with mostly highway driving, but not wears the INSIDES of the front tires out. The outsides of the front tires look great, while the insides of both front tires are BALD!
(I'm thinking some geometry needs addressed, here)
Has anyone else gone through this?
Thanks!
Old Oct 5, 2002 | 06:57 AM
1MAX2NV's Avatar
You need an alignment.
Old Oct 5, 2002 | 07:46 AM
SLC I30t's Avatar
Also check the pressure of the tires. If your pressure lowers the aspect ratio of the tire will roll on a lateral plain. If you are on a low profile tire that can be very bad because you'll be actually running on the 2 ply sidewall instead of the 3 ply tread base.
Old Oct 5, 2002 | 09:20 AM
n2oMike's Avatar
The tires are 205/65/15, so they aren't low profile units. I'm aware how a low profile tire would probably be WORSE.
About tire pressure... I've always run 40psi in the front, 34 in the rear. With highway driving, tire wear had always been excellent. Busting a$$ on these curvy roads has changed that. The treadwear is no longer even... it is HEAVILY biased towards the inside.
It seems, when going around the tight, twisty curves of these West Virginia secondary roads fast... the inside front suspension extends, and when it does, the wheel cambers out and rides on the inside of the tread.
There might also be some Ackerman concerns here as well.
Running less air in the front tires might help with the wear on the inside tire, but the car handles so much better with the extra pressure, I'm hesitant.
I was just wondering if there were 'fixes' out there, like there are for mustangs, etc.
Thanks!
Old Oct 5, 2002 | 12:41 PM
joaquink's Avatar
¿Hablas Español?
Thanks!
Yeah, I had that problem and it was due to incorrect toe-in. Just
get the alignment done and ensure they adjust both toe and camber
(the slight bit that it can be mucked with on our cars). Specs and
methods are available in the FAQ and via SEARCH.
Cheers,
JK
240tomax
Tires and Wheels
Feb 10, 2016 11:01 PM
Turbonut
46
Oct 21, 2015 08:28 PM
Serotta33
Sep 17, 2015 12:14 PM
