Just put on my frankencar...couple questions...
Old Oct 5, 2002 | 11:18 AM
Indecisive311's Avatar
Just got my franken car yesterday and put it on today. I have an 95 auto, and it is 10X louder. I love it..especially under WOT. I can definetly tell a difference in hp to, especially from stock. I've heard to reset the ECU...I had the battery unpluged for about an hour...cus I cleaned the TB to while everything was off. Should that reset it? Also I still have the hood scoop and the bottom of the air box still in there. Should I take it out or leave it in? I don't know because I saw another pipe going below the battery and didn't know what it connected to. Thanx guys.
Peace - Chad
Old Oct 5, 2002 | 11:45 AM
Eric L.'s Avatar
I am just about to install my Frankencar. Question. I removed my MAF but the resonator box is still attached. How do I separate the two? I see a rubber seal between the MAF and the resonator. Is the rubber seal permanently attached to the resonator, or the MAF? I am so afraid of breaking something.
Old Oct 5, 2002 | 12:06 PM
You have to wigle them apart...slowly...they will come apart. I layed it on the floor resonator first...stepped on the resonator and pulled up SLOWLY on the MAF sensor.
Peace - Chad
Old Oct 5, 2002 | 03:00 PM
Dev's Avatar
Dev
Re: Just put on my frankencar...couple questions...
Peace - Chad
yes your ecu was reset.
i just have a JWT pop, but i took out all that other crap in the way. it should just wiggle out. the pipe below the battery, i think thats another resonator, what i did was took out the plastic part that directs air to the airbox, and put the pipe leading under the battery upside down (facing the ground), so that foreign obstacles don't get in.
Old Oct 5, 2002 | 10:14 PM
Re: Re: Just put on my frankencar...couple questions...
Good idea thanx. btw...you spelt "SE" wrong in your sig.
Peace - Chad
Old Oct 5, 2002 | 10:16 PM
s600ergy's Avatar
sup
Old Oct 5, 2002 | 10:52 PM
Eric L.'s Avatar
Re: Re: Re: Just put on my frankencar...couple questions...
Peace - Chad
I think in Canada, the SE model is called ES.
Old Oct 5, 2002 | 11:23 PM
meccanoble's Avatar
Sports Button FTW
Re: Re: Re: Re: Just put on my frankencar...couple questions...
correct. I think that's how it is in japan too...
Old Oct 6, 2002 | 08:27 AM
deezo's Avatar
The rubber seal can be removed.
Indecisive311 I didn't have to reset my ECU when mine was installed. You should be fine.
Old Oct 6, 2002 | 06:05 PM
Re: Re: Re: Re: Re: Just put on my frankencar...couple questions...
My mistake, thanks for correcting me. I still haven't removed the bottom of the airbox yet. I'm still trying to find out what the portion of the tube that goes below the battery is. Is it really a resonator like Dev said. I feel I should remove it because I have to bend the frankencar intake a little to make it fit. Does anyone know?
Thanks - Chad
gigabyte
Jan 6, 2017 06:05 PM
Fbana41
Aug 29, 2016 12:18 PM
zmcneely13
Sep 26, 2015 02:26 PM
lrb6805
Sep 24, 2015 05:03 PM
220k+ A32
Sep 23, 2015 03:38 PM
