ecu help
Old Oct 7, 2002 | 11:03 AM
Redmax's Avatar
Redlinemax Owner
ecu help
my cel came on yesterday, so i searched the site and found the instructions on how to pull the codes. i went under the dash and went to turn whatever it is to get the code and it looked like nothing was there to turn. the seal had already been broken and i couldn't figure out what need to be turned to get the codes! cansomeone help me out!
Old Oct 7, 2002 | 11:17 AM
mayhem_J30's Avatar
you just need a flat head screw driver to fit in there. real easy. get a flash light since it's hard to see. turn clockwise till it stops then counter till it stops.
Old Oct 7, 2002 | 11:48 AM
njmaxseltd's Avatar
You have a 99 SE-L - They share the same ECU as some 5th gens.
You can't get the codes yourself. You need to have a ODBII scan tool.
Old Oct 7, 2002 | 01:00 PM
Redmax's Avatar
Redlinemax Owner
Aint that a BIATCH
Old Nov 6, 2002 | 06:31 AM
MrEous's Avatar
^ Jeff™
Sorry...that's not true. All you need instead of a flathead screwdriver is a smaller phillips screwdriver...like the type you would use on glasses. **read**VERY SMALL**read**
I did it last night.
Old Nov 6, 2002 | 06:47 AM
99CTMAXSE's Avatar
You do need a very small phillips head screw driver. It is very difficult to see. The screw that needs to be turned is toward the bottom of the hole. I think the screw head was white. I hope that makes sense. Good luck.
Old Nov 6, 2002 | 06:54 AM
redmaxpa007's Avatar
i SeE what you did therE
i will call you today and tell you how to check for the code
gigabyte
Jan 6, 2017 06:05 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
Dasmith
Sep 23, 2015 08:28 PM
QueensMAX
Sep 15, 2015 04:14 AM
