'99 se drives rough
'99 se drives rough
I have a '99 Se with about 84,400 miles and the car seems to drive a little rougher than when new. The engine also seems to run a little louder too. I used to have a Cattman Y and a PRCAI but I took them off. Also, had a Crank pulley also but also been removed. I always run synthetic oil (5w-30) and redline transmission oil for my 5 speed. The car is stock and I figure the engine should be smooth and quiet but it doesn't feel or sound right. What could be causing this? I did a throttle body clean and there are no codes showing. Any ideas to make the car run smoother? The car a cali-spec if that could help? I'm pretty familiar with my car and this one baffles me. I drove a '03 SE for a rental for a couple of days when my car was at the body shop and I noticed the '03 was a lot more quieter and smoother than my '99 by way of the engine. Could the grounding wires have anything to do with this? Should there be anything else I can check or adjust? If so, how?
Any and all help would be appreciated! TIA
Originally posted by njmaxseltd
Was the 60K service performed?
Plugs - NGK Platinum If you've got Bosch in there, get them out.
Air Filter
Gas Filter
PCV Valve
Check your engine mounts
Air Filter
Gas Filter
PCV Valve
What should I check on the motor pounts and where are they located exactly?
Thanks!
03-12-2020 12:06 AM
ballerchris510
09-10-2015 09:35 PM
