grinding in reverse
Old Oct 12, 2002 | 12:33 PM
geo1317's Avatar
grinding in reverse
last night when i was backing out of a spot and i turned the stering wheel i heard a realy lowd grinding noise from the front of the car and i felt a slight vibration in the stering wheel as well. But i only get this when im backing up the car and i turn it. It also happens at setain speeds when i make a right run usualy when im in second.
the weather has been bad so i havent had a chance to look at the front of the car but is it the cv joints or what?
Old Oct 12, 2002 | 12:38 PM
Canuck's Avatar
Sounds a little like a cv joint to me.
Old Oct 12, 2002 | 01:00 PM
ericdwong's Avatar
Make sure your brake calipers are bolted in place. I've had this happen before on my old camry, I went in reverse and the caliper would literally dig itself into the rim. Ouch! There was grinding and vibration. It only did it in reverse cause when in forwards the caliper would seat itself with the rotor.
Old Oct 12, 2002 | 01:11 PM
soopermax02's Avatar
Same happened on my '84 subaru. Sounds very similiar to what you report.
Hopefully it's something as trivial as this.
Old Oct 12, 2002 | 01:21 PM
geo1317's Avatar
hopefully tomorrow is a nice day so that i can check these things out. I love how every thing comes in bunches, first my clutch now this. Suspention wouldent happen to be covered under the powertrain warenty would it?
James92SE
142
Jan 2, 2024 09:23 AM
Excalibur23
Oct 13, 2015 04:33 PM
carlosvq30
Sep 26, 2015 09:44 AM
lrb6805
Sep 17, 2015 04:49 PM
