Oxygen sensors
Old Oct 15, 2002 | 07:44 AM
blakkrob's Avatar
Oxygen sensors
Are all three O2sensors the same size and part numbers? I need to replace all three of mine and I'm gonna go with the universal ones.
Old Oct 15, 2002 | 07:48 AM
SuDZ's Avatar
Re: Oxygen sensors
Front two are the same the rear is different.
SuDZ
Old Oct 15, 2002 | 09:05 AM
blakkrob's Avatar
Ok! Thanks. The rear really isn't as important as the front to is it?
Old Oct 15, 2002 | 09:22 AM
Bags's Avatar
VG Ridah's Biatch Hoe
yes the rear helps control the air/fuel mix.. so I would change it as well
Old Oct 15, 2002 | 05:20 PM
Rickalodeon's Avatar
Rear Sensor for Monitoring Purposes Only
I thought I read this earlier...Here's the excerpt from a Daniel Martin post.....
...Most 4Gen Maximas have three Oxygen Sensors. There are two "front" Oxygen Sensors, one mounted in each branch of the Y-pipe. There is one "rear" sensor mounted just downstream of the Catalytic Converter. The Engine Control Unit (the computer) uses the signals from the two front sensors to control the fuel mixture. When the front sensors are operating normally the rear sensor is used only to monitor the performance of the Catalytic Converter.
Old Oct 15, 2002 | 05:23 PM
metallic97gxe's Avatar
Master Will
Re: Oxygen sensors
http://www.automedicsupply.com/catal...c1fe28d4c4efcd
Old Oct 15, 2002 | 08:14 PM
Bags's Avatar
Re: Rear Sensor for Monitoring Purposes Only
yes your correct.. under normal conditioins the rear O2 sensor is not used for engine control operation.. I guess I should have been more specific.. but if it's broke, why not fix it..
Old Oct 15, 2002 | 08:36 PM
tsi maxima96's Avatar
Re: Re: Oxygen sensors
Old Oct 15, 2002 | 09:23 PM
96_vqmax's Avatar
have you try to call nissan to see if your car was cover by the voluntary servive campaign #p8132 & p8152,if it is then you pay nothing for all your three 02 sensor,like mine did.
Old Oct 15, 2002 | 10:14 PM
95seMax's Avatar
how did you not pay nothing, I have a 95 max , 2-3 owner, not sure where car came from
do i just go to any dealer
was it a defect part
do they all fix it for free, what years max qualify
please some more info, my 02 code keeps coming uo
thanks
Old Oct 15, 2002 | 10:37 PM
96_vqmax's Avatar
thanks
the voluntary servive campaign #p8132 & p8152 is for 96 maxima only.vehicle reg in the following state:CA(fed emission only),Nevada,Arizona,New Mexico,Texas,Oklahoma,Louisiana,Florida,Georgia,No rth and South Carolina,Mississippi,and Alabama.Not all 96 are qualify,approximately 150,000 car were affected.So if your car is 96 you can call nissan and ask if you are qualify or not.i think the CEL has to be on,because on the campaign it said 96 max malfunction indicator light (MIL) issues.
TallTom
57
Oct 14, 2025 05:16 PM
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
