OK need some ? answers guys HELP! what a max!
Old Oct 15, 2002 | 03:18 PM
RI-Max's Avatar
Ok guys i've done searches.and found answers but i just wanna get more infor. up to date. these the the problem im haveing with my car and what i thnk it is.if im right or wrong let me know
1-leaking near oil pan( oil pressure sending unit)
2-driver seat moves back and fouth ( thinking a blot/nut must be lose)
3-rpms stick/jump around ( bad gauge cluster)is it the whloe gauge to be replaced?
4-problem starting but starts up every time no click no turn over(???)
5-problem with power windows/locks/lights inside the car cuts off (only when i put the windows up )and u can heard it click back on (bad ground/relay)
6-noise belt when heat/ac is on (need a belt) we have 1 or 2 belts???
7-tranny noise humming/whinding (worn out bearings in tranny)
8-whistle at idle (vaccum leak some where)
i have 134,800 miles on my car
Old Oct 15, 2002 | 03:38 PM
s2cmpugh's Avatar
ok ill try to help as much as i can
1. sounds about right
2. sounds abour right
3. just replace the rpm gauge itself, it is held in by 3 screws in the back of the cluster. also check any connections
4. possibly a bad starter or loose battery terminal
5. please clarify more
6. we have 2 belts i believe (double check that one)
7. i have any auto so i cant help
8. could be a vacume leak, check all hoses
hope this helps at least a little
Old Oct 15, 2002 | 03:44 PM
RI-Max's Avatar
5- ok when im puting the windows up all the power cutz off and about 5 sec. lata i heard a click sound and the power comes back.
4- change the starter 2 twice and battery term. is tight
thanx alot
Old Oct 15, 2002 | 04:26 PM
s2cmpugh's Avatar
5. sounds like you are tripping the internal circuit breaker b/c its getting to hot. only roll up 2 windows at a time, not all 4. it is supposed ot reset itself after a few mins. that is probably it
Old Oct 15, 2002 | 04:28 PM
RI-Max's Avatar
5- thats sounds right thanx that problem solved =)
Old Oct 15, 2002 | 09:12 PM
RI-Max's Avatar
bump!!!!
Old Oct 16, 2002 | 09:05 AM
RI-Max's Avatar
bump come on guys !!
Old Oct 17, 2002 | 05:51 PM
RI-Max's Avatar
bump
MatthewsMaxima
Sep 11, 2015 03:21 AM
maxipower
Aug 21, 2015 11:10 AM
erictown
Aug 20, 2015 08:01 AM
DayHeyZeus
Garage and Workshop
Aug 16, 2015 12:29 AM
Supragte
Aug 12, 2015 10:00 PM
