Clutch makes screeching sound when disengaged in first. why?
Hey guys,
This doesn't happen too often. Thankfully!
What happens basically is this: I come to a stop. When I put it in first, I let off the brake and press lightly on the gas while letting the clutch out... Sometimes the front makes a weird eeeeerrrkkk type of sound, as if metal on metal or something.
this doesn't happen tooo often. It's hapenned 2 or 3 times in the last couple months.
Anyone have an idea what could be the cause?
Brakes not disengaging fast enough, even though I haven't had my foot on the brake for atleast a second or so? Clutch problem?
Curious if anyone has experienced this problem before.
I still can't really tell from searches I've done...does a bad throwout bearing usually cause some vibration-type feel in the clutch pedal? My noise is only at a certain point of disengagement in the clutch (almost instantly before the release point) - it's more of a rumble than an "eeeeerrrrrk" though.
I can sit there and hold the clutch/gas at the same points and let it rumble & vibrate the pedal until I lift off the clutch a little more. I always thought my t/o bearing was shot. Multiplexor - can you do this, or does the noise happen real quick & go away?
Re: Clutch makes screeching sound when disengaged in first. why?
I think you are experiencing "clutch groan" which is common with the OEM clutch. Only happens with 1st gear(occasionally reverse) and not all the time. Do a search on "groan" and you should see a lot of entries. As long as you don't here it in higher gears, you are fine. Aftermarket clutches usually don't have this groan.
