looking for batt+ wire in kick pannel
Old Oct 20, 2002 | 01:00 PM
mb1's Avatar
mb1
is there a power wire running in the driver side kick pannel? If so, what collor is it. I'm trying to install a power seat, and I want the least possible wiring.
Old Oct 20, 2002 | 05:19 PM
(_8*(l)Homer's Avatar
Run new wires. You can hide them. You shouldn't splice into existing power cables, especially with a load as great the power seats. You will either melt wires or blow fuses as the ampere load exceeds the capabilites of the circuit.
Ccan't catch me...I'm the gingerbread man!
Old Oct 20, 2002 | 07:20 PM
WizzaMax's Avatar
You have two options for connection to the fuse box for accessory or always on (like most power seats)
remove your fuse cover,
on the left bank count top to bottom,
the first two are taken and marked,
on mine the third and fourth are both unused and unmarked
the one closest to the top is always on,
the 4th one down is only on with accessory.
try that for power wire with large size fork connector plugging into both spades slots of the one you choose and good luck
best advice is to check each one with light tester prior to taking my estimation for gospel, as I know one is always and the other is accessory but I forget my own name 2 out of 3 times...
Old Oct 20, 2002 | 08:36 PM
mb1's Avatar
mb1
learn something new every day. This sounds like the best option. Thanks Wizza.
trsandrew
Oct 25, 2015 02:47 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
