My Car Is Dead
Old Oct 23, 2002 | 05:08 AM
maxgtr's Avatar
My Car Is Dead
Last night while trying to jump my friends car my car died. Heres the story. Yesterday I had to jump two cars at least three to four times each. Then my friend called and told me that his just died, so Iwent up there and I moved into postion to where my battery would be closest to his, then I turned off my car and got the cables from the trunk. Then I tried to start me car and nothing, not one sound come from the engine bay. Now, I know its not the battery because my lights wouldnt work, and Iknow its not the alternator because then my car would atleasr turn over, but it doesnt do a dam thing. Im thinking it might be the starter, but im not sure, could all the jumps that I made worn something out. Please help, you guys have a good reputation about helping me out when I need it so please dont stop now.
Brandon
Old Oct 23, 2002 | 05:31 AM
njmaxseltd's Avatar
The solinoid on your starter may have given up. Bang on it and try again. Sometimes thats just enough to make it work again. If the problem happens again, get a new starter.
I don't think the jumps had anything to do with it.
Old Oct 23, 2002 | 05:37 AM
maxgtr's Avatar
I dont know even know where it is.
Old Oct 23, 2002 | 05:41 AM
Stephen Max's Avatar
Re: My Car Is Dead
Your lights don't work either? Could be a grounding strap problem, which I seem to recall other people having. Use your jumper cables and run one lead from the negative battery terminal to the engine block and see if that helps. Also be sure your terminals are nice and clean and you've got good contact with the terminal lugs.
Another possibility is an internal short in your battery, in which case your friends just need to buy you a new one.
Old Oct 23, 2002 | 05:49 AM
Conrad283's Avatar
I need a truck
Re: My Car Is Dead
get a hammer and bang (not too hard) on the starter as you crank the car
Old Oct 23, 2002 | 05:58 AM
96SE5Spd's Avatar
Hey guys the banging thing probably won't work this time, Solenoids make a clicking sound if they are getting juice even if they aren't working right. If your lights aren't comming on, Your battery is toast or you have a bad connection. Your alternator could be bad but if it is it probalby just drainded your battery, also your alternator doesn't have much to do with turning your car over, even if it is bad and your battery has a charge the car will turn over or make a clicking noise.
Old Oct 23, 2002 | 06:48 AM
maxgtr's Avatar
sorry guys I just re-read what I typed, and My lights and everything else that involves electrical stuff, such as, power windows, radio, headlights, dome lights, etc. But in order for me to hit my starter Ineed to know here it is, i have no clue where it is. Thank you all for your help, and concern thus far, it feels good to know that I can turn to you guys and gals.
Old Oct 23, 2002 | 06:58 AM
96SE5Spd's Avatar
Ok so your lights do work, Your starter is on the drivers side, right below the stock intake resonator.
Old Oct 23, 2002 | 08:01 AM
Street Reeper's Avatar
Handsome
This happened on mine as well. I just tapped the starter with a hammer (right under the stack air box) and it starteed right up, this is a common problem with our cars
Old Oct 23, 2002 | 05:54 PM
Your "lights, and everything else that involves electrical stuff, etc" what? Do work, or do not work? There's no verb in that sentence.
Old Oct 24, 2002 | 07:18 AM
maxgtr's Avatar
yeah everything electrical works fine, and I did tap my starter and now everything is back to normal again. Thanks everyone that helped out with suggestions. Also does this mean anything like I need a new starter or is this just a common prob?
Old Oct 24, 2002 | 11:27 AM
DaddyMac's Avatar
if you have a manual transmission you can push start your car...
Old Oct 24, 2002 | 11:50 AM
deezo's Avatar
Old Oct 24, 2002 | 01:46 PM
DaddyMac's Avatar
ran out of bananas
Old Oct 24, 2002 | 02:12 PM
choclatemax's Avatar
the starter is on the driver's side towards the back. It's underneath your intake and what not that is around in that area.
Old Oct 24, 2002 | 03:52 PM
Rickalodeon's Avatar
If tapping on the starter worked, then a couple of things [that I'm aware of] are possible. Either there was a questionable connection at the starter, or your starter has a "dead spot". If the problem is the later, then you'll likely be replacing it. I just replaced mine due to a remote starter malfunction which burned it out. Anyway, if need be, it's really a simple job. I spent more time trying to get a good price than it took to replace it. Note: If you end up shopping for one, learn the difference between a rebuilt and a remanufactured unit. The later is preferred.
Good Luck.
Old Oct 24, 2002 | 03:59 PM
BTW...It's always when you don't need one immediately that you find a good deal...I just saw a BuyItNow deal on eBay for a brand new OEM starter for $139 - with 4 days to go. Acme is getting $180 for a reman. Nissan dealers are getting $250 for a reman.
Old Oct 25, 2002 | 06:23 AM
deezo's Avatar
Originally posted by DaddyMac
ran out of bananas
Another dumb comment. You're full of them arent't you?
Old Oct 25, 2002 | 06:27 AM
redmaxpa007's Avatar
i SeE what you did therE
thanks,
Old Oct 25, 2002 | 06:52 AM
Old Oct 25, 2002 | 10:04 AM
95emeraldgxe's Avatar
Originally posted by redmaxpa007
thanks,
i like the pic - lol
Old Apr 30, 2008 | 09:02 PM
kzoosho's Avatar
Originally Posted by rizzindriver89
About a month ago, my car wouldn't really start and almost sounded dead at times. The battery was new so it wasn't that.
My mechanic listed these possibilites:
altenator
starter
ignition
wiring
So i said F#$K that and went on here.
Turns out that running to extra ground cables from your negative to a bolt on the tranny housing and a bolt on the starter works wonders. Try it out before spending hella money on stuff u don't need
I know you are new and all, but um first thing you want to do is check the dates on the threads before you bump them. I and welcome to the org.
Lakersallday24
Jun 16, 2019 01:35 AM
Balkins
Feb 1, 2016 12:45 AM
King_Ten_Ahead
Sep 30, 2015 04:27 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
