My CAI air filter is getting soaked! Problem?
Old Oct 23, 2002 | 10:11 AM
jdspearin's Avatar
Hello,
I have a question regarding my place racing CAI in
wet weather. The instructions say that the intake is only to be used in dry weather. I read all of the old posts regarding this problem
but I am still not convinced. The info I got from the other post
is the following:
1. I could install an AEX valve that would protect me if
The filter went under water.
2. A lot of people said don’t worry if it gets a little wet; there is only a problem if it is under water.
3. Other people said that there is not a lot of water that gets in there anyway.
4. I could also turn the CAI into a HAI.
I have a 98 GXE without fog lights. When I look through the fog light hole in my bumper, I can see my filter. This means that every time it rains my filter gets more than a little wet, it gets rained on and soaked. It is like spraying the filter directly with a garden hose.
My questions are:
Is there any way that water or mist could get sucked up into my
engine?
If so what happens to the engine, and how do I know when it happens?
Thanks a lot!
Old Oct 23, 2002 | 10:17 AM
95emeraldgxe's Avatar
you really shouldnt have to worry about some water getting mixxed in there, if its just a small mist it will probably vaporize in the manifold before any serious damage could happen. You could install one of those bypass valves, but it really isnt necessary. If you're really concerned about it sucking in water, take the lower pipe off and just connect the filter to the midpipe
Old Oct 23, 2002 | 10:21 AM
SuDZ's Avatar
Re: My CAI air filter is getting soaked! Problem?
2. A lot of people said don?t worry if it gets a little wet; there is only a problem if it is under water.
My questions are:
engine?
Thanks a lot!
1. True
2. Yeah, I mean if it is submereged then you up the ante for trouble. Normal amounts of water from splashing should not really travel the whole way up the pipe.
3. They are correct due to the lenght and curvature of the pipe.
4. It would not be a bad idea if your really worried to ease your mind some.
5. Possibly but the past has proven this to be highly unlikely.
6. You will know because it will stop functioning. Dead engine.
SuDZ
Old Oct 23, 2002 | 12:14 PM
JAY25's Avatar
Re: Re: My CAI air filter is getting soaked! Problem?
Originally posted by SuDZ
1. True
SuDZ
Like he said above unless its totally submerged under water would I worry about it. If its a little water dont worry. After driving pop your hood and touch the pipes, ouch they are warm correct. So it will dicipitate not messing anything up so relax. If you want to spend the $45 to get the AEM by pass filter thingy then I would get it if your that worried. I know I seen a member with that AEM by pass that has it on his Max.
Old Oct 24, 2002 | 02:16 PM
Tai Mai Shu's Avatar
Think of the little water that is going in as a ghetto water injection system to increase your horsepower As long as you don't go thru a deep puddle, you should be ok. The warnings are their lawers talking, so if on that outside chance it does occur, you won't go running back to them whining
Old Oct 25, 2002 | 04:23 AM
jdspearin's Avatar
Thanks for the help guys. I can sleep easy now.
Joe
Old Oct 25, 2002 | 11:30 AM
BEJAY1's Avatar
Conecarver
Worry about the dirt & grime building up on the filter instead. And check the cotton/foam, etc. element often for cleaning and/or damage.
97_GXE
20
Sep 17, 2015 08:12 PM
Maxboy23
Sep 9, 2015 10:37 AM
Maxboy23
Sep 4, 2015 06:04 PM
lux97Max
Sep 4, 2015 05:42 PM
sdotcarter
Sep 2, 2015 09:53 PM
