transmission noises
Old Oct 24, 2002 | 11:00 PM
brodaiga's Avatar
transmission noises
I was changing the egr solenoid on my 96 max, I changed the cv joint last week, but never drove the hard afterwards. upon starting the car and shifting to R, I got this really scary loud noise from the transmission, I also checked and noticed the cv joint I installed, the boot was off the joint and grease was coming out, what could have caused this noise? It almost felt as if something was dropped in the trans, I looked around and couldn't see anything, i'm afraid to start it again and try to shift, i'm going to check the codes for ECU tom, let me know if you guys can come up with something.
Old Oct 25, 2002 | 06:08 AM
njmaxseltd's Avatar
Re: transmission noises
You didn't seat the splined shaft into the CV joint far enough for the "C" clip to grap. When you put the car in gear, the drive shaft slipped right out of the CV joint & grinded against the joint slightly (noise) and ripped your boot right off spilling all your grease out again.
Make sure that the splined shaft snaps into place. You'll feel the "C" clip grab and the shaft should not move outwards by hand anymore. I'm suprised you got the shaft back in and the hub back in place without that shaft being seated all the way. It must have been a very tight fit, which should have been your clue that something wasn't right.
Tom
Old Oct 25, 2002 | 08:20 AM
brodaiga's Avatar
Re: Re: transmission noises
Tom
thanks for the help, any tips on how I know it is in all the way?
Old Oct 25, 2002 | 08:22 AM
mzmtg's Avatar
Minister of Silly Walks
Pound it in with a rubber mallet.
...really...
Old Oct 25, 2002 | 08:59 AM
brodaiga's Avatar
thanks guys, now though, the key seems to not want to turn to start the car, maybe it tripped the security sytem somehow? When I get inside with the key in the ignition, with the doors closed, the security light was still blinking, how do I fix this? Thanks.
Old Oct 25, 2002 | 01:54 PM
brodaiga's Avatar
key is still stuck
Old Oct 25, 2002 | 02:04 PM
ericdwong's Avatar
Jerk the wheel side to side while fiddling with the key.
user 11122324
42
Jul 18, 2022 03:35 PM
D Mason
Jun 21, 2016 04:43 AM
