Installing new lights, have a question
Old 10-30-2002 | 06:55 PM
JSClark's Avatar
I have PolarG M14s to go in the clearance lights on my 98 maxima...the Haynes manual I have says to take off the screw on top, then twist till it comes off the clip on the bottom.....all I wanna know is, how hard do I have to twist?? I don't wanna bust the lens or anything....
Old 10-30-2002 | 07:03 PM
gepetto's Avatar
Check the FAQ at the top of the page. It'll tell you how to get out the light.
Old 10-30-2002 | 07:24 PM
JPMax's Avatar
What's next!?..
If it's the first time you're taking them off they might be a little stuck.
After you remove the one screw on top, you need a nice long flat screwdriver to gently pry out the front. If you pull out the light a little and use a flashlight, you can see where it's secured with a pop in metal thing. (what's it called?)
After you pop that out, the housing falls right out.
I actually put some grease on the metal pin and hole that it goes in last time. Now the light's pop off easily by just pulling.
goodluck.
Old 10-30-2002 | 07:29 PM
ladeesman's Avatar
Wrap the screwdriver in a shirt...if you slip you can kiss that pain bye bye. Be careful too, if you push too hard you can crack your lense.
Old 10-30-2002 | 07:46 PM
JSClark's Avatar
Read thru the whole FAQ, and I think I'm gonna try JPMax's idea...thanks though
Old 10-30-2002 | 08:01 PM
Requin6's Avatar
i had better luck sticking my hand down in from the engine bay and reaching underneath. its still a real pain, but the lense housing just wouldnt budge.
Old 10-31-2002 | 02:10 PM
JSClark's Avatar
Yeah, I was almost gonna try that, but I'm not sure, since I got some rather meaty arms
BTW, is that the pacesetter STS in your sig pic?
Viralkill
08-17-2015 10:54 AM
Viralkill
08-16-2015 05:09 PM
doobadoo
08-15-2015 06:43 PM
kirkhilles
08-08-2015 10:53 AM
MikesChevelle
08-06-2015 11:36 AM
Quick Reply: Installing new lights, have a question
