fitment issue with addco rear sway bar
Old Oct 31, 2002 | 07:31 PM
nick's Avatar
ok - today i installed the RSB and there was a fitment issue with
those C clamps that go around the rear axle - they were plain simple too long - there was no way to tighten them up - unleas you use more washers or some kind of spacer in beetwen - does anybody else had the same problem ????? other that that imstall went smooth - took it for a spin and noticed nice tightnes in the back - felt like somebody put 200 lbs of weight in the trunk - the car was "planet to the ground " altogether kyb agx , sprints , fstb, rsb work great
Nick
Old Oct 31, 2002 | 07:45 PM
clee130's Avatar
I don't think you need washers or anything like that.
If it's on there and it's tight, there shouldn't be any problems.
Old Oct 31, 2002 | 08:05 PM
Conrad283's Avatar
I need a truck
the install was pretty easy though?
Old Oct 31, 2002 | 08:10 PM
clee130's Avatar
Install is super-easy in my opinion. The first time, it took me and my brother just an hour to do it ... and that's only because we put it on upside-down the first time and realized it half-way through.
The toughest part I think is just holding the bar up. A friend to help you out is a good thing.
Old Nov 1, 2002 | 05:35 AM
DigitalTexan2u's Avatar
I've posted this several times.....
Here's my write up on "HOW TO INSTALL AN ADDCO RSB"
Enjoy:
Clicky here
Old Nov 1, 2002 | 05:43 AM
Axra's Avatar
Enjoy:
Clicky here
Nice write up.
Old Nov 1, 2002 | 08:29 AM
nick's Avatar
great write up and pics !!!!
anway - after seeing this write up i can rest in pace
I did everything right- the same way, with one exeption
those C clamps that go around rear axle were too long - so I used
spacers and work perfect !!!! really satisfied with rear of the vehicle beeing so "planet to the ground"
Nick
Old Nov 1, 2002 | 02:49 PM
mlocke's Avatar
Either I'm missing something ...
... or you installed it without sockets (metric and deep metric) or metric combination wrenches. I can't figure out how spacers would be needed.
Old Nov 1, 2002 | 03:22 PM
Re: Either I'm missing something ...
Yeah....I never used spacers and mine is just fine?
Old Nov 1, 2002 | 11:14 PM
cocolopez's Avatar
Re: Re: Either I'm missing something ...
hey buddy i know whats ur problem, i had the same. call addco, tell them ur problem, theyll send you the kit to fix this right up. i ordered my RSB from custommaxima, called greg and he told me addco was shipping out some wacko bars and to call them and let them know. theyll send u the kit free of charge (no shipping, nothing!)
hope this helps!!!
when i put my rsb on, i was like oh my god wtf!!! i hope this thing from addco comes pretty soon.
www.addco.net for their phone number.
Old Nov 3, 2002 | 01:53 PM
BOZOnPJs's Avatar
ok what about a front end sway bar?.. how come no one talks about putting one on
Old Nov 3, 2002 | 02:27 PM
kevinsean23's Avatar
Same issue
Yeah, I also was installing the rsb from custommaxima.com and the c bars were way to long. So I just took everything off and emailed greg at custommaxima.com requesting that they mail me the correct parts.
Also wondering, is the bar like this: ] supposed to be very hard to fit by the brake line? I'm worried that this part may be wrong also.
Should I just stretch it out a bit and force it on with tools?
Kevin
Old Nov 3, 2002 | 03:45 PM
Conrad283's Avatar
I need a truck
Re: Same issue
Kevin
all you need for the "C" bracket is a 14mm deep socket and the nuts will go all the way up ... and the [ brackets go on a little snug, but it'll go on
Old Nov 3, 2002 | 07:25 PM
+COLLANA+
defective
Mine fits good.
And for that Front strut bar question, yes, it fits beautifully.
Old Nov 3, 2002 | 09:11 PM
WizzaMax's Avatar
Cause they come with them already...only thing I did was swap stock bushings and control arm bushins to Energy Suspension polyurethane ones...just did this today.
Old Nov 3, 2002 | 10:20 PM
justmax's Avatar
Re: Re: Same issue
Incorrect. I had the same problem. The threading on the C bracket ends about 1 1/2" too low so the nuts won't go all the way up. Also, the ][ brackes I got were WAY!!! too short to fit over the control arm. I called and emailed Addco for a month until they finally send me 4 new brackets that fit perfectly.
Old Nov 4, 2002 | 04:08 AM
cocolopez's Avatar
Re: Re: Re: Same issue
isnt this what ive been saying since the beginning...?
Old Nov 22, 2002 | 08:27 PM
B1GMATT's Avatar
Haha, had the same problem tonight with my install. It's took a few spacers for the long U bolts and alot of "persuasion" to get the [ bolt on. Too bad I didn't see this thread before. Silly me... I thought when you bought something it should come with the correct hardware.
Old Nov 22, 2002 | 11:44 PM
Mine came with correct hardware?
No problems here....
ef9
Aug 27, 2015 07:21 AM
seesole
Aug 26, 2015 11:22 AM
Dasmith
Aug 25, 2015 10:15 PM
Maxboy23
Aug 20, 2015 09:33 AM
MaxStock
Aug 14, 2015 10:03 PM
