Help, how to remove side AC vents??
Old Nov 2, 2002 | 08:15 AM
kickyoazzz's Avatar
does anyone know how to remove the side AC vents or at least just the frame? not the defrost vents but the adjustable ones. i tried prying them off from the bottom, they gave a little but i think if i kept on going i wouldve cracked them from the middle.
Old Nov 2, 2002 | 10:32 PM
kickyoazzz's Avatar
up, no one knows?
Old Nov 3, 2002 | 09:49 AM
totallymaxedout's Avatar
Re: Help, how to remove side AC vents??
On the driverside you have to remove the fuse cover...feel up in the dash towards the vent, there should be a screw holding the vent in from the inside this has to be removed with a sideways screwdriver or a small nubby ratchet and socket..On the passenger side, the glovebox has to be removed in order to get to this screw..the removal procedure is the same as the driverside...Hope this helps out
Old Nov 3, 2002 | 02:13 PM
kickyoazzz's Avatar
Re: Re: Help, how to remove side AC vents??
thanks buddy. so after i remove these 2 screws , the vents should pop right out?
Old Nov 4, 2002 | 05:53 AM
Re: Re: Re: Help, how to remove side AC vents??
Yeah the vents should pop right out with little resistence..There will be some resistance b/c of clips but they should COME RIGHT OUT...
The Frye
Sep 2, 2021 11:03 AM
Mar 12, 2020 12:06 AM
t6378tp
Sep 29, 2018 04:27 PM
spidgeon
Sep 9, 2015 03:36 PM
Colossus
Sep 9, 2015 05:46 AM
