RPM question
RPM question
Hi people,
I change my spark plugs and the pcv value yesterday and when i turn on my car the RPM needle goes above one. Once the car is warm up the needle goes below one. Is this normal ? Any input is welcome. Thank you in advance.
Re: RPM question
Originally posted by taggate
Hi people,
Hi people,
Re: Re: RPM question
Originally posted by 98SEBlackMax
Yes the stock Maxima engine idles higher 1 K ~ 1.5K rpms when its a cold start and then normally drops below 1K and stays around 750~850 rpms when it warms up.
Re: Re: Re: RPM question
Originally posted by NiNe7-Gxe
cold start my car is 1-1.3k and when its warmed up its 500-600 is this normal? 500-600 seems very different from your 750-850
I'm SC'ed, and I idle at about 650. I idled at 600 when I was stock.
IanS
If you clean your throttle body you'll notice an even bigger jump, depending on how dirty your TB was before. I cleaned mine after 100K miles. Before cold starts would happen at 1100 rpm. After the cleaning, 1500 rpm. Also, low end pickup was better, too.
DW
DW
DW
DW
