Whirrring sound? Water pump?
Old Nov 4, 2002 | 04:59 AM
dmirocha's Avatar
I own a 95 GXE with 129K miles. About 2 months ago, I noticed a whirring sound that increases in pitch with RPM. It does it in park or drive which pretty much rules out the tranny. Constant pitch when cycling the A/C on and off too. Just a hunch that it's the water pump. Any other suggestions?
Anybody out there have a good source for water pump replacement procedures? Also, any suggestions on what brand pump to get would be appreciated.
Thanks,
Darby Mirocha
White 95 GXE
Old Nov 4, 2002 | 05:57 AM
funnylittlman's Avatar
Where is it comming from exactly?
Old Nov 4, 2002 | 06:02 AM
dmirocha's Avatar
I haven't listened to it that closely, other than just raising
hood.
Old Nov 4, 2002 | 07:56 AM
69CHARGER_RT's Avatar
Could be the alt belt tensioner or the alt
Old Nov 4, 2002 | 11:13 AM
munji's Avatar
sounds like what i had, the noise was rather loud, and i originally thought it was belt or tensioner pulley related. here's what i did: pull off all the belts and start the car, if it is still there, there's a good chance your water pump is shot. if you are still skeptical, use a stethoscope. this will also tell you if it from bearings or not.
Old Nov 4, 2002 | 11:16 AM
munji's Avatar
by the way......i was seriously thinking of it as DIY job but after talking to my mechanic I decided to let him tackle it, since I did not want to take any chances jumping the timing chain. If the chain jumps then you have to pull the heads to realign, and if you crank it with the chain improperly fitted, you can bend the valves since the VQ is a zero clearance engine.
Miket2006
Mar 1, 2021 03:55 AM
AaronL
Aug 8, 2020 10:31 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
