60K Mile Car ISSUES... idle, car feels sluggish, and slow startup...
Old Nov 4, 2002 | 04:30 PM
thebigsadler's Avatar
Well my alternator has been replaced recently, my oil gets changed every 2-3000 miles and the plugs were changed at 40k, along with the tranny.
For the past few weeks the car has been throwing oil pressure sensors, somewhat overheating (not the car, but the gauge) and it has felt sluggish. The car doesn't start right up like it used to and it seems to be very sluggish at idle... especially when cold (burbles and sputters).
Could this be a knock sensor, or compression issue??? The car is going to nissan in a few days when my new ABS sensor gets here to have those 2 checked, but any ideas.. ??
-Jason
Old Nov 4, 2002 | 04:33 PM
SuDZ's Avatar
Re: 60K Mile Car ISSUES... idle, car feels sluggish, and slow startup...
-Jason
When my knock sensor had issues it was not like the ones yoru describing other than sluggish, but maybe check the ECU for them anyhow If the knock sensor is bad it could be throwing other things off as well.
SuDZ
Old Nov 4, 2002 | 04:35 PM
Re: Re: 60K Mile Car ISSUES... idle, car feels sluggish, and slow startup...
SuDZ
The ECU isn't throwing any codes as of now.. what else would the knock sensor throw that would cause these issues?
Old Nov 4, 2002 | 04:42 PM
D1NOnly34's Avatar
Re: Re: Re: 60K Mile Car ISSUES... idle, car feels sluggish, and slow startup...
The Knock Sensor doesnt throw a code when something is wrong, cause its a "ghost code". Im pretty sre that if you check your ECU, you might just get a code, nut you might not, no hurting in checking.
Old Nov 4, 2002 | 04:49 PM
Confused's Avatar
Permanent Maxima.org Resident
when was the last time you changed your fuel filter?
Old Nov 4, 2002 | 05:04 PM
D1NOnly34's Avatar
Ive been having similar problems, but to a more severe case. I have athread going on trying to figure out what the hell is wrong with my car. I got 2 codes, knock sensor and ignition signal circuit. Didnt get a check engine light though. Anyways, Ive changed my spark plugs, checked coil packs, changed air filter, and just put in fuel filter. If I were you, change your fuel filter, when was the last time you changed it? Could be about that time. What kind of gas do you use? This all makes a difference =/
Old Nov 4, 2002 | 05:33 PM
fuel filter changed around 50k i believe and i've run premium fuel 92-93 octane since 24k when i got the car.
so i should just do the ECU code thing with a screwdriver and see if anything pops up??
jason
Old Nov 4, 2002 | 05:34 PM
D1NOnly34's Avatar
jason
Yes most definetely, your answer lies there.
Old Nov 4, 2002 | 05:45 PM
0505 engine code thrown.
Old Nov 4, 2002 | 05:46 PM
Vyrus's Avatar
Jason I have those exact same problems, and the car goes to the dealer tomorrow to get them checked out. BTW if you listen closely the whine can be from the passenger's side of your engine bay, which would be a belt squealing. I'll let you know what they are when I get home (~5:00 PM). I'm thinking knock sensor but it's not throwing any codes.
-Cyrus
Old Nov 4, 2002 | 06:58 PM
-Cyrus
I got 0505 code.. but there is nothing for it in the faq's.. so i don't know what it means.
no squealing here..
Old Nov 4, 2002 | 07:58 PM
Vyrus's Avatar
no squealing here..
Somebody else IMed me a while back with that code... they didn't know what it meant but posted in the General Forum and got some answers. Might want to check that out.
-Cyrus
Old Nov 4, 2002 | 07:59 PM
I30tMikeD's Avatar
0505 means all is good.
http://forums.maxima.org/showthread....hreadid=104931
Old Nov 4, 2002 | 10:35 PM
SuDZ's Avatar
What about other tune up items like spark plugs or what not?
SuDZ
Old Nov 4, 2002 | 10:47 PM
ny96max's Avatar
-Jason
you think thats bad, im over 100k and on a cold moring my remote start wont even get my car to kick on, it just stalls out
oh and Jay a knock sensor wont cause your car to do what its doing. Trust me, when i had mine done i noticed better acceleration and a lil smoother idle.
Ant
Lakersallday24
Jun 16, 2019 01:35 AM
maxinout93
Oct 27, 2015 01:29 PM
Ray229Harris
Sep 16, 2015 08:16 PM
MikesChevelle
Aug 10, 2015 10:53 AM
yat70458
Aug 3, 2015 01:16 PM
