Brighter Headlights Mod
Old Nov 6, 2002 | 05:47 AM
mforrest100's Avatar
Ok. I need some varification on this mod. I heard from a fellow org member that if you take the ground wire from for your headlight and ground it to the chassis this will make your headlights brighter because when you ground the wire to the chassis it frees up some power that was going thru resistnace before you grounded it to the chassis. Has anyone done this?
Old Nov 6, 2002 | 06:23 AM
nadir_s's Avatar
vicodin ... gift of life
Re: Brighter Headlights Mod
it wouldn't hurt? Well, rather than cutting it, you could try splicing the ground wire to the chassis. It may be brighter... but if so, at least it will lower the "dimming" whenever you roll ure windows down or whatnot.
Old Nov 6, 2002 | 07:36 AM
96BLUMAX's Avatar
Yeah i have noticed that our cars have a big problem with dimming while rolling down windows etc. Is that the ground's fault?
Old Nov 6, 2002 | 12:20 PM
ThurzNite's Avatar
If you're gonna do that, then go all the way...ground the headlight to the neg battery terminal!
Do a search on "hyperground" to learn more about grounding benefits.
Jae
Old Nov 6, 2002 | 12:29 PM
99MAXSE-L's Avatar
or jus buy a uprgrading wiring harness, does the same thing, hook positive to the battery and ground from chassis...can handle 100/80w bulbs...i jus bought mine from suvlights.com
Old Nov 6, 2002 | 12:42 PM
nadir_s's Avatar
any grounding upgrades you do will ONLY bring your electrical system/whatever performance the way it was when it was brand new outta the factory. Technincally this would only make it as bright as it was when the car was first made. Over the years, ground points and electrical system do degrade causing resistance.
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Oct 25, 2015 02:47 PM
Noela
Sep 26, 2015 08:22 AM
