Car won't start
Car won't start
hey guys.. lont time no post
anyway here is my problem.
i parked my car at home... then later i want to go fill it and get a sandwich
engine light comes on... stays on... car won't start
i get code from ecu
05 05
which is .. no failure detected.
still car wont start.
gas was on E... but i went to get gas and now it's above E.
all the electrical seems to work... radio.. lights..
i checked ignition fuses... they look fine..
i'm stumped.. and it's dark out... any sugestions ?
108k miles SE 96
D.
i get code from ecu
05 05
108k miles SE 96
D.
i cant help with whats wrong with your car, however my car starts fine but then it dies like a second after i start it( it only does this when its cold, sitting for 5 hrs or more) any suggestions and do you think this will cost alot?
throttle body cleaning
when was the last time you cleaned your throttle body?
http://www.motorvate.ca/
engine --> throttle body cleaning
and check your wires. 95-96 maximas are known for starter problems and bust ground (-) wires.
ok.. update
the engine did not crank.. the only noise was the relays you hear from stuff being turned off while you turn on the car, etc.
BUT... today my car started fine..... ? ? ? ? ?
the dif. between today and last night is.. a bit warmer out.. and it's raining
i'm gonna check wires because i can picture a bad ground in dry weather that might be good when it's moist.
but... i will try that throttle body cleaning.. can't hurt..
i also know my knock sensor is bad, but i've been putting that off and using high octane gas... but still that should be ok
i did notice.. that if i rapidly turn key to ON over and over.. then it won't start... i had to wait another few seconds and then it started...
i don't know...
i think my starter is on the way out....
anyone know where i can get it tested ?
i don't know...
Re: ok.. update
To cut the story short, I believe it's your starter. If this happens again, try this:
Keys on ACC, press the brake pedal and move your auto shifter from P to N (manual, don't worry about this, just take that stick out of gear).
Then, move your car either forward or reverse just a couple of milimeters.... so don't try to hard to roll it like 1 ft. or something, just try to get the car rolls a bit.
Try to crank it again. If your second start is successful, than it's definitely your starter.
My car does this like once every 100 starts.
Originally posted by SamMan23
I think your battery cables might be lose.
if you just hear a *click click* sound... the connection it has to the battery is not conducting well. It would start in the morning... but when you run the car or if the temprature inside the engine bay is hot, it will not start because w/ the heat, there is more resistance and doesnt' allow it to conduct well. So... check all your wires.
well guys
I swapped out my maxima for a yugo and everything worked fine from then on.....
lol
thanks for you input guys.. i will check all connections this weekend and clean anything that needs cleaning.. i'm due for my next checkup and may wait till then.
but thanks
everything seems fine now.... :?/
lol
but thanks
well... cr*p
ok...
my car was at the giant parking lot for 6 hours the other night
what finally got it to start was that i tapped the starter with a wrench ( afriend suggested i do this in case the brushes were dirty on the electric motor )
when i got home.. it started 3 times then nothing..
the next day ..
i held the key to turn on the car..
it started to turn, just barely starting the engine then repeated the cycle like 7 times... barely starting the engine every time.
new starter i guess.... it seems pretty easy for me to do anything i should know ?
autozone has one for 140 with a 40 dollar core charge... what is that ?
the next day ..
Re: well... cr*p
The core charge is for the old part. The $40 will be returned to you when you bring in the old starter.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
BobMax
Aug 15, 2015 12:35 PM
