Need advice from the detailers out there.
Old Dec 27, 2000 | 08:04 PM
Special K
I have a 97 SE with (what looks like) hard water or acid rain spots on the outside of the windows. Anyone know how to get this stuff off? I have tried razor blades, wax and even steel wool but nothing works. Any suggestions???
Old Dec 28, 2000 | 12:19 AM
Slickismax's Avatar
STEELWOOL!?!?!?! Im sure your window is scratched to he11 now! There are different waxes out there that will take those off. The stuff I used to use was called fireglaze. If nothing else, just take it to a detail shop and they should be able to get it off. YOu just need to find a light compound.
Old Dec 28, 2000 | 08:04 AM
Maxfreak
I used to work in a detail shop and believe it or not you can polish your glasss with a buffer. Get your hands on a buffer/polisher and apply a good wax to the glass and use the same back and forth motion that you would use on your paint, be carefull not to get the buffer close to any plastic molding on the car, you will burn it and then the clean glass is worth nothing. Good luck.
Old Dec 28, 2000 | 08:36 AM
JimW
Bon-Ami works wonders for glass--->
It's like Comet, but it's much finer grade that won't scratch. Go to the supermarket to the cleaner aisle, next to the scouring powders, you'll see Bon-Ami. I think it still has the little yellow chick on the side of the can.
Mahmuth
Aug 16, 2024 08:23 PM
gigabyte
Jan 6, 2017 06:05 PM
Pnjboyzz
Nov 16, 2015 12:27 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
dshinn
Sep 26, 2015 08:07 PM
