KYB Dustboots for 95 GXE
Old Nov 12, 2002 | 02:52 PM
95gxe_vl's Avatar
I have inquired at KYB about Maxima application, and they said that there is no boot application for 95 Maxima. I would really appreciate if you can provide me with KYB application number for the front and back dustboots. Tirerack.com and tires.com say they don't have that info either. I have KONI/Eibach combo. Thanks.
Old Nov 12, 2002 | 03:03 PM
Requin6's Avatar
arent all 4th gen strut assemblys the same?
Old Nov 12, 2002 | 03:04 PM
jdmmax's Avatar
hmmm so far the suppose kyb dust boosts that i have worked with didn't fit right on 4th gens. just go with oem its the easiest way
Old Nov 12, 2002 | 03:11 PM
Requin6's Avatar
i have the KYB dust boots and i am sure many others do as well. they work and go on very well maybe we are thinking of different parts. the dustboots i got for my AGX's are from Cattman.
Old Nov 12, 2002 | 03:21 PM
jdmmax's Avatar
hmmmmmmm wierd we were at a install meet a while back ago the guy had kyb dust boots and we were having a problem getting everything back toghther. it wasn't just me.
hmmmmm did you cut anything
Old Nov 12, 2002 | 03:25 PM
Jr'sMaxima's Avatar
I also do and got them from cattman....so dont know who told you that!
Old Nov 12, 2002 | 03:53 PM
Requin6's Avatar
nope, didnt have to cut anything. just put the dustboot on the strut piston while the compressors were still on the spring, assembled the top of the assembly, let the compressors out, and then worked my fingers inside the spring and pushed the top of the dustboot into place fitting itself where the OEM one was located.
i left the bottom un-ziptied until i torqued the main nut on the top of the assembly while it was in the car so the boot did not get twisted (the piston turns a little when the main nut is tightened) once that was all torqued down i zip-tied the bottom of the boot to the red bottom piston housing (where its detailed in the directions) and its been all good.
--Paul
Old Nov 12, 2002 | 03:57 PM
jdmmax's Avatar
--Paul
hhmmmmmmmmmmmmmmmmmmm ok thanks
Old Nov 12, 2002 | 04:45 PM
GlenH's Avatar
got KYB dustboots on my 96 GXE and fits fine. The rears are a 100% perfect fit. The front's do not snap into the upper mount, but fit snuggly on the piston shaft. I like them better than the OEM dustboots. Get them from Cattman. I don't think they are designed specifically for Maximas. That is why KYB does not list a specific application for our cars. But, they DO fit with no problems.
Do a search under my screen name. I wrote a long message about my experience with these dustboots that should answer your questions.
Old Nov 14, 2002 | 09:37 AM
95gxe_vl's Avatar
Thanks to everybody replied. I was able to find the part numbers. They are SB103 for the fronts and SB108 for the backs. BTW Cattman is backordered on them. Thanks again.
Old Nov 14, 2002 | 10:54 AM
breaux124's Avatar
I used the KYB dust boots without any problems on my 97SE. You can see the pictures I took here:
http://www.bryanb.com/site/maxima/parts/parts.html
I took a picture next to a dollar for reference, people want to see how much of the bump stop was pre-cut with the KYB boots. Hope this helps out.
Old Nov 14, 2002 | 11:12 AM
mitch33x's Avatar
I have KYB dust boots and they fit my AGX's perfectly
Old Nov 23, 2002 | 11:31 AM
Nismo82's Avatar
hey - to all the brains - can I reuse my stock dust boots? I am getting agx's next week and want to know if I can use mine. (I also read about havine to modify kyb's boots?)
I just want tostay with mine.
Old Nov 23, 2002 | 09:54 PM
95gxe_vl's Avatar
If your stocks are in good condition, yes, you can reuse them, and you will have to cut the bumpstops. You don't need to do this with KYB dustboots, they fit perfectly. From my experience, don't zip-tie them, use metal clamps from radiator hose, they keep it in place much better. My $.02.
Old Nov 24, 2002 | 06:19 AM
Lime's Avatar
if you're running eibachs and konis, why would you want KYB dust boots? That being said, heh heh, the dust boots SHOULD fit any 4th gen application.
tarun900
19
Dec 20, 2021 06:57 PM
maxima-junky
Oct 7, 2015 06:13 PM
Socalstillen
Sep 20, 2015 11:46 PM
