Small RPM drop when headlights turned on, Normal?
Old Nov 13, 2002 | 12:16 PM
96max5sp's Avatar
My rpms go down slightly and my car runs a little rougher when I turn my headlights and radio on is this normal? I have aftermarket Xenon headlights and parking lights. Thanks I'm just wondering if I should have my spark plugs changed or not cause I don't if the dealer I got it from at 66,XXX miles did it or not. I have 72,800 miles on it now. how often should I change them anyway?
Old Nov 13, 2002 | 12:18 PM
iansw's Avatar
The revs dropping a little is normal.
You should change your plugs (assuming your using the stock NGK Plats) every 60,000 miles.
IanS
Old Nov 13, 2002 | 12:19 PM
njmaxseltd's Avatar
Headlights on = load on electrical system
Load on electriacl system = alternator works harder
Where does the alternator get it's power from?
YOUR ENGINE!
Old Nov 13, 2002 | 12:23 PM
JeffesonM's Avatar
living out of a maxima...
someone a while ago mentioned something about upgrading your wires if you have HIDs... because even though the regular wattage is only 35w, it takes 75w to fire them up and as they're first warming up.
someone also grounded them directly after the bulb, instead of back into the stock ground and reported brighter lights.
njmaxseltd... I know you just sold you HIDS, but do you or anyone else have any thoughts on either of these things?
Old Nov 13, 2002 | 12:43 PM
96max5sp's Avatar
Thanks for your responses. I knew that it takes a load on the alternator I was just wondering if it was normal. In my 88 civic wagon it did this did I was just wondering if it was the same in a 6 cylinder
Thanks again
Old Nov 13, 2002 | 01:09 PM
njmaxseltd's Avatar
The start up is a fraction of a second, (you can see the blip) after that their being powered by a 35W supply. The start up load isn't much either. It's a voltage spike that fires them up. Just like a spark on a spark plug which is several thousand volts, with very little current flow.
HID systems use about 18% LESS power to operate then a regular 45W halogen bulb. You do not need to do any upgrading of your electrical system to run an HID system. It's actually a lighter load then your car is designed for.
Old Nov 14, 2002 | 05:08 AM
95Max's Avatar
Do you have read HIDs? Since I replaced my battery I do not get s dip. Also the headlight dimm when you put the windows up is gone.
Old Nov 14, 2002 | 05:33 AM
funnylittlman's Avatar
Did you guys see the thread in the general forum abt. a new hid kit w/ dual beams HIGH (XENON) Low (HID) both on 1 bulb. No more worryin about passin inspection for me!
Finkle
Sep 27, 2015 09:53 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
beboski
Aug 16, 2015 05:23 PM
doobadoo
Aug 15, 2015 06:43 PM
altome15
Aug 10, 2015 07:05 PM
