ABS and fog lamps
Old Nov 13, 2002 | 12:27 PM
99NJMAX's Avatar
ABS and fog lamps
I've got a 99 GXE without ABS, heated seats, ect. I want to install the oem fog lamps, but either 1) I can't find the harnesses or 2) they're not there. Is this something I can add myself or will i have to go to Nissan to add the harnesses. I don't want to go to my local dealer because i have a feeling that they'll want to bust my ***** about my intake. Do I have any other options?
Old Nov 13, 2002 | 01:20 PM
nadir_s's Avatar
vicodin ... gift of life
Re: ABS and fog lamps
If you can get the harnesses (i'm not sure if it's already on the car stock or not... prolly not) then you can do it yourself, definately. Look for someone selling them... i thought there was a group buy goin on w/ em, not sure but check it out. I know you'll have to cut out the rubber panels that cover up the holes where an OEM fogs would be. Other than that... i'm sure it's simple mounting.
Old Nov 13, 2002 | 01:37 PM
99NJMAX's Avatar
forgot to mention that I already have the fog lamps. I'm not sure where I can get harnesses to plug into the lamps themselves. I want to avoid going to a dealer for installation as much as possible.
Old Nov 13, 2002 | 02:13 PM
SupermaxGxe's Avatar
Are you sure you dont have the harness? I thought all Maximas came with them. I have a GXE and installed the fog myself, it was easy. the harness should be attached to your headlight wires. They're taped on, cut the tape and you could just connect them from there.
Old Nov 13, 2002 | 02:29 PM
mzmtg's Avatar
Minister of Silly Walks
GXEs without the C&C package do not have the factory wiring.
Old Nov 13, 2002 | 02:32 PM
ThurzNite's Avatar
Yes, you have the stock wiring. Everything's there. If you want, I can go take pics of the harness in my GXE. If you trace the headlight harness back, you 'll find a coiled up wire/harness. It's just underneath the headlight. That's what you need. Just thread it down to your fogs and hook them up.
You'll also need a relay, which you can purchase at radioshack for 2.99. Just hack off the lil section that sticks up (you'll see what i mean when you get it).
And finally, you need the fog light stalk (same stalk as turn signal and headlights, but with added "ring" to control fogs)
Jae
Old Nov 13, 2002 | 02:37 PM
99NJMAX's Avatar
if you want, I can go take pics of the harness in my GXE.
I'd really apreciate if you could. that way I'll know what i'm looking for
Old Nov 13, 2002 | 03:38 PM
jiaxima96's Avatar
If you buy the OEM fog lamp kit, the relay is included.
Old Nov 13, 2002 | 03:55 PM
99NJMAX's Avatar
I have the relay, switch, lamps and brackets. The only problem is my car is not equiped with harnesses for the fog lamps. I don't want to go to a dealer because i know they'll want to charge me some ridiculus amout for the stupid harnesses and wiring.
Old Nov 13, 2002 | 04:37 PM
jiaxima96's Avatar
I remember someone here mentioned that if a Maxima is not pre-wired, it still has some pre-wire from switch location to somewhere under the hood, most likely to the fuse box. That means you only need to wire from fuse box to fog lamp location, instead of going through the firewall.
Don't remember who said that.
Old Nov 13, 2002 | 04:42 PM
jiaxima96's Avatar
If you take off the plastic cover on the steering wheel, look for a connector hanging there for the fog light switch. If not there then no luck.
Old Nov 13, 2002 | 07:39 PM
(_8*(l)Homer's Avatar
What is taped to the headlight wiring? I have fog lights, and there is still a connector taped to the headlight wires. Does power go to that unused connector when I have the fogs on? It is cold and rainy, so I don't wanna go out with a multi-meter to test. That, and it is also night.
Old Nov 13, 2002 | 11:44 PM
ThurzNite's Avatar
yup, that's it. guess i don't have to post pics. heehee.
Jae
trsandrew
Apr 8, 2016 06:45 PM
mpbclutch33
Dec 26, 2015 11:11 AM
trsandrew
Oct 25, 2015 02:47 PM
Calabar
Oct 5, 2015 09:57 PM
leatherneck
Sep 30, 2015 09:16 PM
