installing white glow gauges
Old Nov 15, 2002 | 07:45 AM
95maxima's Avatar
last night i installed some white glow gauges i bought from e-bay on my 95 maxima. I finished, connected everything back together, but now none of my needles move! trip odometer and the other odometer work, and the check engine light stil works but the only thing that doesnt work are the needles. what do you supposed the problem could be? what would they charge me to fix it?
Old Nov 15, 2002 | 07:49 AM
Conrad283's Avatar
I need a truck
Re: installing white glow gauges
maybe the gauges aren't on there all the way causing a little rub between the needle and the gauge therefore making it stationary
Old Nov 15, 2002 | 07:57 AM
95maxima's Avatar
thats what i was thinking, gonna have to take that thing apart again
Old Nov 15, 2002 | 08:29 AM
96BLUMAX's Avatar
Yeah how did you secure the new gauge faces?
Old Nov 15, 2002 | 09:07 AM
95maxima's Avatar
they didnt have anything to secure them with, i used tape,should i return them, i got them from procarparts on e-bay.
Old Nov 15, 2002 | 11:51 AM
Ramius83
The black plastic bezel that surrounds each gauge is what sorta holds them in place. With that tape you are using, you are raising the face of the gauges closer to the needles, hence why they won't move because the gauge faces are touching the needles. Either try removing the tape completely and try installing them without the tape or put a little piece of tap on each corner of the gauge face to keep it in tact.
Old Nov 15, 2002 | 11:59 AM
venompwr2's Avatar
DOUBLE SIDED TAPE! I had the same problem, put some tape underneath and screwed the gauge faces on with the original screws, work just fine now.
Old Nov 15, 2002 | 01:33 PM
phenryiv1's Avatar
Mod her. Ate her.
http://forums.maxima.org/showthread....ighlight=faces
Try that thread there. I had the same problem with OEM SE white faces. It took a few trys to resolve, but eventually it all worked out. Read that and PM me if you have any questions.
Old Nov 15, 2002 | 01:36 PM
SuDZ's Avatar
The needles always seem like a delicate thing to touch. It seems people are always haveing problems when they try to change them out.
SuDZ
Old Nov 15, 2002 | 10:11 PM
95maxima's Avatar
nothing will happen to the white face gauges if i put a screw through them?
Old Nov 16, 2002 | 05:41 PM
phenryiv1's Avatar
Mod her. Ate her.
Drill them out first, if the material is heavy enough...that is what I did...
Old Nov 17, 2002 | 03:00 AM
JPMax's Avatar
What's next!?..
Yea, I just installed my indiglow gauges on my 95 GXE today.
I noticed the gauges weren't very secure after I took the screws out. I tried using super glue on the posts each gauge was sitting on, but that didn't work. Finally I figured I would have to find a way to reuse the screws.
I compared the new faces with the old to see approximately where the screw holes would have to be. There weren't any circuit lines under the new faces in the areas that needed drilling so I figured it was safe.
I think the screws really help prevent the needle sticking problem since they hold the center of the face down and also keep the whole gauge from moving around.
I'll take it out for a spin tomorrow and see if there are any problems.
BTW: Other things I did today..
1. Installed self made aluminum bezel (painted metallic black)
2. Gunmetal gauge rings
3. Painted needles translucent red.
I'll have to take some pictures tomorrow. Too tired now..
Think I need some blue blubs.. heh.
MaxLife17
Jun 27, 2019 01:37 PM
captchaos
Mar 15, 2016 12:18 PM
doctorpullit
Sep 10, 2015 06:33 PM
Maxima.KsA
Sep 8, 2015 11:33 PM
Johnny9595
Sep 3, 2015 05:18 AM
