*Help* ...replacing a caliper...
Old Nov 15, 2002 | 08:48 AM
Dayle97SE's Avatar
I'm in the middle of replacing one of my rear calipers, and i'm also putting in speed bleeders and flushing out the brake system. I just need to know how tight should the speed bleeders be and also how tight should the bolt for the fluid line (banjo bolt??) on the caliper be? anybody have numbers for ft.lbs. torque? thanks to all who respond.
Old Nov 15, 2002 | 09:00 AM
njmaxseltd's Avatar
I don't have #rs for ya.. but keep in mind that those fittings are brass. Thats soft metal, so go easy on them. Just snug them up good, don't go nuts on them.
Old Nov 15, 2002 | 09:08 AM
ejj's Avatar
ejj
IIRC bleeders should be in the neighborhood of 50 in-lbs (NOTE INCH POUNDS!).
For the banjo bolt I usually get it snug, then about a quarter turn. I would guess 20-25ft-lbs tops.
Also, before you try to tighten the bleeders, make sure you have a flare nut wrench. A socket or normal wrench will strip the head of the bleader in NO time.
Old Nov 15, 2002 | 12:31 PM
sinewave's Avatar
According to the '99 FSM, the rear banjo bolt is 17-20 ft/lbs and the bleeder is 7-9 ft/lbs.
bryants95max
Oct 2, 2015 12:52 PM
rnb754
Sep 14, 2015 11:39 PM
0m3nc0w
Sep 11, 2015 05:21 PM
