Crank pulley: Unorthodox vs RVM
Old Nov 15, 2002 | 04:42 PM
speedemn's Avatar
I read each and every post regarding underdrive pulleys here. What I got out if it was that the RVM pulley is 1.7 lbs and the Unorthodox is 1.56 lbs. Other than that however, has anyone had a chance to compare the 2 pulleys? How is the quality of the RVM? Are there any dyno numbers for the RVM vs the Unorthodox? I guess you'd have to compare using 2 similar cars to see if the gains match up for both pulleys.
Lastly, are the belts the same for both pulleys? This is what I have gathered for the UR pulley:
Alternator & Water Pump
1995-02 Gates # K060408
Power Steering
1995-02 Gates # K040292
If this one does not fit then try: Gates # K040300
I'd appreciate it if anyone could post their findings on this.
Thanks!
Old Nov 15, 2002 | 05:02 PM
SuDZ's Avatar
Re: Crank pulley: Unorthodox vs RVM
Power Steering
Thanks!
Regardless of the weight if the circumference is the same (which I figure it would be) then they should be the same belt sizes as well.
SuDZ
Old Nov 15, 2002 | 05:16 PM
Jime's Avatar
Think you are right Sudz, other UR pulleys for other vehicles have been cloned and sold cheaper. Probably the same with this one.
Old Nov 15, 2002 | 05:28 PM
JeffesonM's Avatar
living out of a maxima...
I just got the RVM pulley and have yet to install it, but it looks to be of good quality.
Old Nov 15, 2002 | 05:31 PM
speedemn's Avatar
Is the diameter of the RVM pulley the same as UR?
RVM's site said that their pulley is BIGGER diameter than stock, but much lighter in weight. Is that true? I thought that the UR and RVM pulleys were both smaller in diameter than stock.
Old Nov 15, 2002 | 05:39 PM
Street Reeper's Avatar
Handsome
I'm about to change my belts, and am going ahead and getting a lighter UDP probably from unorthodox. Anyone know of the best place to buy one? I did a search but prices are constantly changing, I was wondering what the newest best place to buy one is?
Old Nov 15, 2002 | 05:40 PM
JeffesonM's Avatar
just out of curiousity, why would you pay twice as much for Unorthodox Racing brand vs. RVM?
Old Nov 16, 2002 | 06:18 AM
Handsome
Hadn't heard of RVM.
I didn't know that there was a significant difference in price. I will get the RVM.
The Unorthodox weighs 1.56, the RVM 1.7, what's the stock pulley's weight
Old Nov 16, 2002 | 07:23 AM
Jime's Avatar
Originally posted by dwapenyi
In order to drive the accessory belts at a slower rpm, they would both have to be bigger than stock. A smaller pulley would drive the accessories faster, and put more load on the engine.
DW
If its an underdrive pulley it has to be smaller. A larger pulley would make it drive faster not slower. Larger on the alternator or power steering would make it drive slower but not the drive pulley.
Old Nov 16, 2002 | 07:43 AM
dwapenyi's Avatar
Oops, my bad Brain fart.
DW
TKHanson
Nov 24, 2018 01:39 AM
chisam14
Nov 6, 2018 08:56 PM
BkGreen97
Apr 2, 2016 05:47 AM
zmcneely13
Sep 26, 2015 02:26 PM
msellas
Sep 23, 2015 09:16 PM
