Fuse for headlights?!?!?! please help!!
Old Nov 18, 2002 | 03:00 PM
95maxgxe's Avatar
hey my right headlight stopped working so i got new bulbs and it still doesnt work! is there a fuse for the headlights that i could check?? what could be the problem otherwise? the bulb works fine in the left headlight, so i know the bulb is fine! thanks for the help
Old Nov 18, 2002 | 03:20 PM
1FSTMAX's Avatar
Yeah each headlight has there own fuse. They are located under the hood on the drivers side. It's one of the little boxes that contains the fuses, and relays.
Old Nov 18, 2002 | 04:24 PM
95maxgxe's Avatar
hey thanks, i checked the fuse and it is fine, any ideas as to what could be wrong?!? thanks
Old Nov 18, 2002 | 04:28 PM
1FSTMAX's Avatar
Humm... The only thing that I can think of would be, a damaged or burned out healight harness, or a defective bulb socket. Have you checked your wiring, to make sure it's ok? Have you checked your bulb socket as well?
Old Nov 18, 2002 | 04:42 PM
(_8*(l)Homer's Avatar
Was the previous bulb a higher wattage bulb? You could have fried your wiring if it was. If the bulb in the other socket is also a high wattage one, take that out and put the stock ones back in. High wattage means above 45/65w low/high respectivly.
(_8*(l)
Old Feb 11, 2003 | 06:55 PM
NUGE's Avatar
hey 95maxgxe, did you ever solve your problem?
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Oct 25, 2015 02:47 PM
leatherneck
Sep 30, 2015 09:16 PM
Noela
Sep 26, 2015 08:22 AM
