Car has a hard time starting
Old Nov 19, 2002 | 09:07 AM
1lapdawg's Avatar
Ok, here is the problem with my 96 SE. When the temperature goes belpw 40 degrees and the car sits overnight or all day while at work it is difficult to start the car without it stalling. To start the car and keep it from stalling I have to give it gas. Basically it seems like the ECU doesn't know to give it gas to let it idle when cold. Again this only happens in cold temperatures and the car has sat for several hours.
Thanks for the help.
Jeremy
Old Nov 19, 2002 | 09:34 AM
ZuMBLe's Avatar
You may have a dying starter like many of us. Or a bad alternator. My car does the same thing. I'm going to replace the starter soon.
Old Nov 19, 2002 | 09:38 AM
dmplus's Avatar
My 95 GLE with 202,000 miles does the same thing, on cold mornings i have to give it a little gas when starting. After that it's fine
Old Nov 19, 2002 | 10:54 AM
njmaxseltd's Avatar
A few things to check regarding starting and idling issues.
1) Clean your throttle body. www.motorvate.ca has instructions and pictures.
2) Your Engine Coolant Temp sensor may be out of spec.
3) There is a plunger on the throttle body which kicks up your idle speed when the car is cold. It's located down under the throttle body by the linkage assembly. That plunger should come out when the car is cold and press up against the fast idle cam. If your not getting a proper cold idle speed, that plunger may not be working correctly. There is also an adjustment screw for the fast idle cam.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
02PearlSE
Oct 7, 2015 02:12 AM
Balkins
Aug 12, 2015 06:39 AM
mrgooch
Aug 9, 2015 11:00 AM
